Results 1 to 4 of 4
Thread: will these fit?
    ghtito is offline LX Newbie
    Dec 2007
    will these fit?
    I want to run 22x9.5 5x115 25mm offset on stock RW magnum, price is right and discontinued color somewhat matches the silver metallic paint. any help is appreciated. Also would like to know if the offset is wrong if a spacer or adapter (cringe) would work or if your running this set up any rubbing issues? Almost bought them but need a second or even third opinion.
    israel's Avatar
    israel is offline Now That's Woo Ha!
    Seal Beach,CA
    You're going to need at least 10mm spacers with that offset. I wouldn't add anything more than 5mm. The price is wrong if it doesn't fit right.
    tommyzdesign's Avatar
    tommyzdesign is offline just an lxer
    Jun 2005
    anywhere theres a Lxer in need.....
    what israel said , youd like 15 to 18mm for the RWD r/t. i dont think those will even go on without hitting your brakes or spindles.
    Dec 2007
    thanks for the info, I guess the search continues
