hey there, is anyone running a 255 on a stock rim? i wanna upgrade to wider tires, and just happen to need a rear set. i have my eye on some 255/55/18 which are a little taller, but i wanna get some width...
any info appreciated.
thanks
brian
thanks
brian
This link should help with the wheel/tire fit and let you know about MPH changes.
http://www.wheelsmaster.com/rt_specs.jsp
As far as rubbing... I have seen others here with that 255 up front and up to 295 in back.
I kept the 245/45/20 in front and went to 275/45/20 out back. A little taller in the rear looks kind of old school - I like!
FLXC & SSP MEMBER
Jeff's LX: 07 Magnum R/T, Road & Track Package Diablo tuned!!, Blacked out and & Red Lit Billet grills, Drilled Rotors & painted calipers, 3G Firewall & ABS Covers,Air Raid CAI & DIY ram-cold air hose, Reso delete, 180 T-Stat, Eyebrows & HID Lows & Fogs, touch screen w/HDTV-1800w of Amps & 10' Sub, R/T Shifter ball. Hemi Reg# 1220
LLLATER!
I got 255/45-18 KDW2s on stock rims, they like 50 pounds for compition and 35 for normar street use.
05 Magnum RT 5.7 (Member ALLPAR.com 200,000 mile club) Rockinsrt8 shifter, Hemi reg #164 266,666 miles (c'mon John, I slowed down! NOT)
Sidewinder, 6.1 pushrods, springs, underdrive pulley, SRT exhaust (donated by NHDave) headers to tips, all installed by Hemi31! Quaife, certain Pedders bushes installed, SRT Nivomats and Bilsteins. Police rotors and pads. HIR. Predator. LMI.
1:19 NJMP Lightning
1:45 Mosport
I've seen a couple LX's with 255/55R18's on the stock RT wheels.
They do fill the wheel well nicely.
They "calculate" at 29 inches tall as compared to the stock 225/60R18's 28.6 inches tall.
In appearance, they seem too wide for the wheel width. The rubber bulges quite a lot from the rim.
I don't know who makes a 245/55R18 tire, but I believe that you would like that look the best. Wider but maybe not too wide in appearance. Same diameter, so no speed calculations necessary.
Good luck with your quest.
Terry
2011 Charger SE (blackberry)
2011 Ford Raptor
I have a set of Toyo Proxes 255/55/18's and simply love them.
They fit the wheel wells nicely and give my Magnum sort of a NASCAR look.
Check out this link for somone who put 255/50/18's on the front and 275/55/18 on stock rims of a Charger.
Staggered on stock rims, 275/55-18 and 255/50-18
The ones that I have are the one's on the front, but Mine are 255/55/18. Work very well.
I chose to not go with 20's or 22's because I always "Rashed" my previous low-profile wheels.
Look around in the Used Tire places...
The Proxes are usually take offs from Smaller Trucks.
I got my entire set for $240...
Good Luck.
Taz
These are some pictures of My magnum with the Toyo Proxies 255/55/18 tires on them.
Hope this helps you decide.
Taz
I have Nitto NT420S 255/55/18 on my Magnum and what a difference.
These are by far the best tires I have put on the Mag. The side wall sticks out over the rim just a little bit, but does not look bad.
Have no clearance problems. Also to add they have a bad ass looking tread pattern.
Check the photobucket link in my sig, the Nitto Redlines are 255/45-18 and the BFG kdw2's were 255/55-18.
Mike
Originally Posted by JusticePete
My Pedders ExperienceOriginally Posted by JusticePete
Anyone have Pics of a 255/45R18 tire on stock R/T Wheels.
2005 Silver Magnum R/T-
5.7L Hemi Registry #1327
New Build In Progress
LOTS OF PERFORMANCE ITEMS FOR SALE
