Results 1 to 10 of 10
    VelocityBoy's Avatar
    VelocityBoy is offline Stroked AND Blown
    Feb 2007
    Cambridge, Ontario
    Wheels And Tires - Magnum R/T AWD
    Hiya,
    I need help making a decision regarding rims and tires for my Magnum. Spring is approaching and I'll need to get something soon.
    I have an 06 R/T AWD Magnum. I'm looking for Black 20" rims and staggered tire formation.
    I'm looking to balance ride comfort with performance.
    I was considering perhaps 245/45/20 front and 275/40/20 rear. I'm not an expert on tires/rims so I have no idea what will fit. I heard something regarding unusual offset on the Magnum that makes rims hard to find.
    Looking at sites like Tire Rack, I do not see much of a selection when it comes to tires/rims. I'm from Canada, so I'm looking for someone who will ship it there.
    Any input is appreciated.
    Cheers,
    Tom
    Turf's Avatar
    Turf is offline '05 Dodge Magnum SXT AWD
    Jan 2006
    Michigan
    stock AWD rims are 18x7.5, 5x115, +55 offset. too low of an offset, and the wheels will stick out past the fender
    staggered wheels and tires will be a problem since you are driving all 4 wheels. the consensus seems to be that the computer will have trouble with different sized wheels between front and back, best to stay with the same size on both.
    check discount tire, they seem to have more choices for the AWD.
    try the google site search since it allows searching for 3-letter words, look for AWD wheel posts.
    Feb 2007
    Cambridge, Ontario
    As I understand the AWD Magnum, still puts out 2/3 of the power to the rear wheels. Wouldn't wider tires in the back improve traction?
    Cheers,
    Tom
    done's Avatar
    done is online now Member for 7 years
    Old Hickory, TN
    Quote Originally Posted by BThunderW View Post
    Cheers,
    Tom
    Not without a bunch more horsepower, say about 500 or so.
    Kim Hufty is offline LX Padiwan
    Southeast Mi
    BThunderW
    There are lot and lots of threads about wheels that fit the 4WD's and the "widest tires" take the time and do some searches. I think you will find there are a few (not a lot) options available to you 4wd's.
    SHAKER check, Heads check , Cam check , tuner check, CAI check, LT 's check, Borla check, ext, ext, ext
    12.8358 @ 108.46
    Token's Avatar
    Token is offline First AWD LX in the 12's N/A
    Center of the LX Universe
    Check with Ernie at Avon Custom Wheels. (Supporting Vendor)
    He's awesome to deal with, and has become somewhat of an expert at Canadian shipping, well Lori has anyway. If not they know where to get some help.
    12.645@108.18
    Feb 2007
    Cambridge, Ontario
    I was just looking for some clarification on rims vs tires. What size rims goes with what tire etc. The whole offset thing kind of confuses me. Why does smaller positive offset stick out farther than larger positive offset. Or more to the point, what's the absolute max offset that will fit (i.e look good) on the AWD.
    I guess I'm trying to attack this from both sides. Match tires to rims and vice versa.
    Cheers,
    Tom
    Token's Avatar
    Try playing with this:
    http://www.bigcustomwheels.com/rt_specs.jsp
    Might help to understand what fits
    12.645@108.18
    F1fan's Avatar
    F1fan is offline "There can be only one"
    Nov 2005
    MPLS, MN
    I'd give up on the notion of a staggered fit. The required offset really doesn't allow it.
    rpg
    rpg is offline Black 05 AWD
    Jun 2006
    Central Massachusetts
    Buy my 20" wheels and tires from a 2005 R/T AWD with 1,236 miles on them! Buy the Brembo brakes at the same time!
    20" Momo Storms w/ 255-45-20 Toyo Proxes, 1200 miles
    Brembo GT brakes, 20" Momos and Proxos, 1,200 miles, from 2005 AWD Magnum
