Results 1 to 15 of 24
    dwhip's Avatar
    dwhip is online now DMV SLEEPER
    Jan 2008
    VA, but born in that 202 SW
    Wheels are rubbing my control arm, NEED SUGGESTIONS!!!
    Whats up my fellow lx'ers, i ran into a little problem. A friend of mines sold me his wheels at a good price, because he is moving out of the country. I installed the wheels on the rear with no problem, but when i installed them on the front, the wheels were hitting the control arm. The wheels have a offset of 35 which is wrong for rwd chargers, but i want to know if anybody out their have any suggestions. The wheels are 20x9, 35mm offset, and i tried using 5mm wheels spacers, but it still wasn't enough clearance.
    When U see me in my town Everything is BLACK & RED!!!!
    viper3ez's Avatar
    viper3ez is offline Hello, my name is Nuvie.
    Jul 2007
    Bronx, NY
    mine cleared the control arm with 3mm spacers and they were 22x10. check around see if anyone would grind the control arm for you. i could not find anyone to do mine and i still want to so i can take out the spacers.
    Quote Originally Posted by gr8crash View Post
    Its like paying $6K for your girlfriend to get a great boob job, then meeting a girl that has better boobs that are natural, are you gonna complain cuz you paid $6k for boobs for an Ex that aren't as good as the one in your hand? I think not.
    Super T's Avatar
    Aurora, IL
    Get bigger spacers I guess, or ideally sell the wheels and buy a set with the right specs for your car!!! Anything wider than like a 10mm spacer and you should probably get longer wheel studs too.
    I'd sooner walk than drive a car with a chunk ground out of a control arm.... you'd be introducing a HUGE stress concentration point that could frankly dump your wheel if you hit the wrong pothole.... not a good option IMHO.
    STREET LIFE R/T's Avatar
    STREET LIFE R/T is offline Maryland's only Wide body Charger!
    Elkridge, Maryland
    I would buy the right wheels...I have seen some bad pics of wheel spacers going bad....IMO.
    Derrick @ Auto Performance Aesthetics Club
    APACAUTO@HOTMAIL.COM
    36 chambers's Avatar
    36 chambers is offline Banned
    ON A HOLLYWOOD SET NEAR U!!!!
    Bigger Spacers Or New Wheels.. Only Fix!!!
    dwhip's Avatar
    Jan 2008
    what size spacer you think i would need?
    israel's Avatar
    israel is offline Now That's Woo Ha!
    Seal Beach,CA
    I guess the price wasn't right if the wheel doesn't fit.
    Super T's Avatar
    Aurora, IL
    Stock offset for a RWD is 18, right? So like 20mm? Or am I doing that math wrong? I get confused between backspacing and offset.
    israel's Avatar
    Seal Beach,CA
    If a 10mm, spacer doesn't help, I would'nt bother. I would never recommend using a spacer larger than a 10mm.
    Mighty Noid's Avatar
    Mighty Noid is online now time to paint the car soon!!!
    Aug 2005
    SoCal
    Take a grinder to the control arm... you can take off about 3mm (1/8") with no problem. Then when you are done paint it back and then put the 5mm spacers back on and it should be ok...
    Thank you Bigal470
    israel's Avatar
    Seal Beach,CA
    I misread your first post. Your car is a RWD, Right? There is no way these are gonna work. Get your money back or sell them.
    israel's Avatar
    Seal Beach,CA
    Quote Originally Posted by Mighty Noid View Post
    Do not listen to this guy!! Never grind down the arm, never!!
    Aug 2005
    SoCal
    Many people have done this in 2005 and 2006 and they have never had anytype of issues or problems. Plus just removing 3mm is not that much at all.
    Thank you Bigal470
    Quote Originally Posted by israel View Post
    this guy iz knows his wheels and offsets.....id listen to him!!!!!noid knows his stuff too... hes just crazy!!!!!!we have pictures to prove it
    DannyC's Avatar
    DannyC is offline Loudest SXT
    Nov 2006
    Lynchburg, VA
    AWD wheels are not designed to work on RWD. Get the proper wheels. The tires will work on the proper wheels.
