I found a set of wheels I really like but they only come in 18"x8 with a 4.5" backspace.Since I have no idea how to convert CM to inches,will this fit my Mag?
BFNY PERFORMANCE
RIP My Friend
4.5 " = 11.43 cm
1" = 2.54cm
No I'm not that smart have a conversion calculator
Yes that is a 14mm offset, so they will fit.Originally Posted by Hemi31
Hemi31, Is the bolt pattern 5-115? You'll want to make sure of that before you purchase these wheels too.Originally Posted by Hemi31
They are 114.3.I'll get the rings and they will be fine.Anybody remember the old Magnum 500 wheels from the Chargers and 70's Road Runners.I found these in Billet and 18x8.
BFNY PERFORMANCE
RIP My Friend
Hemi31:
I would be surprised if they work. That is an old style RWD wheel which is not what our Magnums run. Don't get backspace confused with offset, they are not the same.
Here's a link to a chart that converts backspacing to offset.Originally Posted by done
http://www.rsracing.com/tech-wheel.html#backspace
Look up the 8" width wheel with 4.5" backspacing and the offset is zero. The minimum offset we need for our cars is 10mm.
So, no, these wheels will not fit.
Nuts!
BFNY PERFORMANCE
RIP My Friend
Their chart is wrong. From their page, the definition of offset.Originally Posted by VanillaRT4me
Wheel center line from Wheel backspace to get offset.
If backspace is less than the wheel centerline the offset is negative
If backspace is greater than the wheel centerline the offset is positive
The centerline is 4" so 4.5 offset is greater by 1/2" or 14 mm.
wheel width is to the inside of the wheel lip... centerline goes to the outside of the lip..Originally Posted by done
so the total wheel with outside to outside is 9" .. backspacing is 4.5" .. inside wheel width is still 8" ..
So will the damn things fit or not?This offset stuff is new to me,they should have just stuck with backspace!
BFNY PERFORMANCE
RIP My Friend
Just ask them what the offset is on the wheel. Any thing from 12 to 24 will work.
