Results 1 to 15 of 18
    gooeytek's Avatar
    gooeytek is offline heavy hemi
    Jun 2008
    Lake Grove, NY
    what's the widest tire we can run on the rear of the Mag?
    Mag RT, rear wheel is 20x10, +25mm offset. car will be lowered about 1" from stock. I'd like to run 315/35/20's in the rear, is it possible?
    http://www.lxforums.com/board/signaturepics/sigpic23029_3.gif
    MY HEMI REGISTRY PAGE
    ... Do it for fun and enjoy the improved performance, but don't think you made a transaction that makes any financial sense. Use the economy numbers to torpedo the tree hugger who wants to get snooty with you, but know in your heart you did it so you could go faster.
    progolfer82 is offline LX Padiwan
    Oct 2009
    SoCal Ride: SRT8 Mag
    You should be able to. I had 275 and was no problem and have heard of 305 with no problem so seems like it would work. good luck
    SILVR24s's Avatar
    SILVR24s is offline Keeping It Simple
    Feb 2008
    Arlington, WA.
    It should work, i know that mines rub so i had to add 1/4" spacers, but i am running 24X10 with 255/30/24 tires.
    HIS: 2005 Dodge Magnum R/T- 22" Foose Nitrous rims, 180 T-Stat, Flowmaster cat-back exhaust, Mopar intake, SRT suspension, billet grille, tinted tails, taylor shorty spark plug wires
    HERS: 2011 Dodge Charger Rallye- Mods coming soon.
    FinallyCharged's Avatar
    FinallyCharged is offline <<<<<<(SDMopar.com)>>>>>>
    Jul 2009
    San Diego,CA
    i have 22X10s on the back with 295/30s with no problem at all
    gooeytek's Avatar
    Jun 2008
    Lake Grove, NY
    I was more concerned about the width as an issue, since the backspacing of the wheel would be right about at 6". I'll probably need a 1/4" spacer or so, for the rear. I think 275/40's will fit in the front with 20x9's.
    MagnumManAWD's Avatar
    MagnumManAWD is offline LX Oddball
    Jun 2008
    Central FL
    Be careful with spacers as this puts strain on the outside of the wheel bearings where it wasn't really designed for. It wont cause a terribly fast wear, but it will wear them a little faster than normal.
    Magnum Man
    Hemissary's Avatar
    Hemissary is offline Made from solidified electricity...
    Calgary, Alberta
    The largest that will still collapse up into the wheelwell is 315/35/20. After mounting, you need to carefully check lateral clearance, I needed to shift the cradle to ensure equal clearance to the inner fender lip both sides:
    ---VIPER--VENOM--RED-- -------------------------------- Hemissary--at--CarDomain-------------
    Bubba's Dragon's Avatar
    Bubba's Dragon is offline The NEW KRT
    Mar 2006
    Daegu, South Korea
    I'll add another question for this .. Just got a set of stock SRT rims, what are the widest tires I can run thanks allso (in the rear)
    KRT:
    2005 BLACK Dragon:
    MODS: None, pure Natural Dragon
    gooeytek's Avatar
    Jun 2008
    Lake Grove, NY
    I've heard of people having 295's on the stock SRT wheels with no probs.
    Hemissary, that's exactly what I was looking for. What's the offset on those SLR replicas?
    typicalmarine's Avatar
    Jun 2007
    Maryland
    I'm running 275/40/20 without any problems and you can see that my car is quite low.
    n2fordmuscle's Avatar
    n2fordmuscle is offline LX Guru
    Dec 2008
    Canton, GA
    Quote Originally Posted by gooeytek View Post
    I'm running 275-40-20 with 20x8.5 on the front with no issue. And 295-40-20 with 20x10 on the rear. Rears are Mustang rims, so I added an 8mm spacer to make them work. No issues with vibration, etc. I plan to go with 315-35-20 when it's time for new tires.
    NYCSRTATE's Avatar
    NYCSRTATE is offline I Wanna Go FAST!!!!!!!!!
    City That Never Sleeps
    I dont have a Maggie but im sure you can get a 315/35/20 rear in there with the right offset, I did on my Charger.
    Hemissary's Avatar
    Calgary, Alberta
    I had to machine the wheels to fit the LX platform (they used to have a 112mm on-center bolt pattern); they are only available with a 35mm (Mercedes) offset, so I machined hubcentric spacers (0.75" front, 0.50" rear - sourced proper wheelstuds), the actual offset on the rear to fit the 315's works out to 23mm.
    The 315's under heavy cornering loads (at the track) can force the corner of the tire (where the tread meets the sidewall) into the plastic inner fender liner (along the most forward portion of the tire). This creates superficial rub marks on the inner fender liner itself. Otherwise, no contact anywhere even during full suspension collapse (keep in mind the top outer corner of the tire moves progressively inwards as the asembly moves up and into the fender well).
    gooeytek's Avatar
    Jun 2008
    Lake Grove, NY
    Good to know. Looks like the sweet spot for the rear wheel offset might be around 18-20mm then. What's your suspension setup like?
    Hemissary's Avatar
    Calgary, Alberta
    Harsh, but very sure-footed; not sure what you are asking me :^)
