i'm just got my self a pair of Vredestein 315's and i'm starting to wonder if i'm going to have any space issues in the rear, the rims are 20X10.
2006 Dodge charger R/T w R\T
Made You Look & Drool Mods:Ram Air Hood, Tu-Tone (Silver & Black) 20" Vipers, Grip Tuning Body Kit, CBD Engine Bay Goodies, BT Interior+Engine Bay Goodies, CF Dash Kit, RiderGraphix & AAC Red Halos (F+R) + 50w HIDs
Made You Scream For Your Life Mods:
FRI 426ci Complete Engine Fully Heat Coated, CMJ Track Killer (355 Rear Gears), KW V2, Brembo GT 6 Piston Front 4 Piston Rear, Arrington 90mm TB, CF WarHammer, ProTQ 2800, Dynatech LTH & Corsa Cat-Back.
They will fit
BFNY PERFORMANCE
RIP My Friend
Yup. Maybe a slight chirp on the fender on a large bump during extream cornering. But they fit fine and feel great!! This is a rough picture. I will be posting a bunch more maybe this weekend. I just had a 1" drop with Pedders springs. Have to be paying attention to avoid a rub with the drop but still not very often.
looks like i'm gonna have to raise it a bit and stiffen up the ride
just get your fenders rolled if you are worried about them rubbing
Hey, friend. I'm not an alarmist but you should certainly consider rolling your fenders as Pete stated. I had rubbing issues with my 20x10 vipers and 295's combined with almost a 2" drop in ride height. After rolling the fenders it was okay. The front was worse at the fenders and the backs rubbed the fenders only slightly, as well as the inner wheelwell a tad. Good luck.
John Y
382 RWHP / 411 RWTQ 12.25@110.46MPH![]()
Here's a link with a detailed description. This is the 'correct' way to do it. I did mine with a piece of 2" PVC pipe and a lot of care.
John Y
Thanks John, i'm gonna get that tool for sure.
the wheel well remains though
i've seen modified wheel wells getting sold for corvettes in order to fit 13" wide rims
