    Dr Teeth's Avatar
    Dr Teeth is offline LX Guru
    Nov 2006
    Calgary, Alberta, Canada
    Vibration Problem
    OK, here's my dilema. I bought a set of rims from Discount Tire Direct in early June. After I put them on I had a vibration at about 80 KPH, enough to make the steering wheel visibly shake, so I took the car to a local tire store and had them balanced. No difference.
    Next I took the car to a local specialty tire store (Harper's Tire) had the road force balance done. Their machine said that two of the tires were marginal, but they managed to balance them anyway. That seemed to do it. No more shake at 80 KPH and 110 or 120 was OK too. I was completely happy, until my local LX club (Alberta LX) had a big M&G at an acerage about 250 K north of here. Driving home I tucked in behind a buddy's Charger. Everytime he and I hit 140 KPH I got a wicked vibration through the car. OK, here we go again.
    I called Discount Tire and explained what was going on. They felt the problem was likely due to the marginal tires, so they sent two more up, and I booked another appointment with Harper's tire to have them installed.
    The morning of the install I took the car out for a run so I could describe the exact symptoms. To my surprise I could take it to 180 KPH without any vibration! I have no idea why it vibrated above 140 earlier on the highway. Anyway, I figured I had the tires anyway, so I may as well get the marginal ones replaced.
    After Harper's replaced the two marginal tires and re-road force balanced the other two rims I took it for a spin. CRAP! The vibration and steering wheel shake I had at 80 KPH before was back, only now between 90 and 100. So last night I decided to do some self diagnostics. I swapped the right front for the right rear. No change. Then I swapped the left fornt and left rear. Still no change. Finally I decided to put the stock rims and tires back on. Bingo, no more vibration. Today, just to see if the vibration might somehow have been caused by the stiff sidewall on the aftermarket rims, I decided to increase the inflation on the stock tires to 51 PSI (the max on the sidewall). They now ride as stiff as the 20 inch Falkens, but still no vibration, so it's not a sidewall stiffness issue.
    Obviously the aftermarket tires and or rims are the cause, but I'm still confused. Whay would the vibration above 140 KPH vanish without doing anything? And the new vibration (with the two new tires) would come and go on a straight stretch, almost like something was going in and out of phase, yet on a straight stretch the tires should rotate at the same speed, so they shouldn't go in and out of phase.
    I'll be calling Discount Tire tomorrow morning, as well as Harper's tire, but in the meantime does anyone have any idea what the problem might be.
    PS: I made sure all the hucentric adapters were still present (and the right size), the lug nuts show an even wear pattern all around the shoulder, so the shoulder angle seems correct; and I torque everything incrementally with a torque wrench. The rims are 5 on 115, not 114.3 (or at least that's what Discount Tire said when I bought them)
    __________________
    2006 300 SRT8. Black. Razors Edge Shock Tower Brace, Diablo Predator, Torque Thrust M's, Nito Invos, BT catch can.
    Dr Teeth's Avatar
    Nov 2006
    Sorry, I forgot to mention that I also took the rotor retaining clips off when I first mounted the rims.
    Dr Teeth's Avatar
    Nov 2006
    I know no-one posted to this, but in case anyone read it, here's an update:
    Discount Tire finally asked me to send the rims and tires back for them to look at. After they received them they said they looked as good as could be. They didn't know why they were causing an issue on my car, but they offered to take everything back and return ALL the maoney I had spent. That includes the rims, tires, shipping, customs fees...everything. I was VERY impressed and I'd recommend them to anyone!!
    Anyway, I still wanted some rims so I opted for some 19 X 8.5 inch ASA JH8s and 255/50/19 Continental Contact UHPs. I don't know what the difference is, but now my problem is GONE! The car has no vibration and drives as smooth as with the OEM rims and tires.
    Just for everyone's information, the first set I had was Voxx Ancona 20X8.5s with Falken 452s size 255/45/20. I'm not adding this to slam Voxx or Falken, just to provide info in case anyone else has a similar problem.
