Page 1 of 4 123 ... LastLast
Results 1 to 15 of 48
    monty1269's Avatar
    monty1269 is offline Looking for a job too...
    Aug 2005
    Pompano Beach, Florida
    VERY scary!!!! Tire failure...
    Any ideas???
    Tire almost let go! Steel and split....Shown below...
    Billet Tech Goodies EVERYWHERE Diablo tuned!! Inertia SPARTAN CAM 214/218, 113 LSA, 3.06 gears, FTI 3600 TC, 17 X 8.5 Borbet TS w/ 275/40 Hoosiers : Hemi Registry 0436
    Best 60'= 1.896 (stock TC and gear) ET= 12.841 (pre-Eagle heads & 6.1 intake manifold)
    JarZ's Avatar
    JarZ is offline Ole sad på en knold og sang
    Union County, NJ
    Ooh that is not good. Glad nothing happened while you were driving.
    2005 Bright Silver Dodge Magnum R/T - Inertia 5.7 heads/Spartan cam/JBA headers/AFE II/BB Fat Pipes/402 Motoring spoiler/tinted tails
    2006 Brilliant Black Dodge Magnum SRT-8
    5.7L & 6.1L Hemi Registry # 856
    JarZ@Inertiamotorsports.com
    Please call us at 512-964-7724/862-215-4668 or send me an email for any questions about our products.
    Find us on Facebook Or @inertia392 on Twitter
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Is that the rear or the front??
    DAYTONA3949's Avatar
    DAYTONA3949 is offline The All-Seeing Eye
    West Palm Beach
    Two much spartan!!!!!!!LOL
    MIKE'S
    TOP BANANA 3949 (SMOKE'N) 6.1 w/forged pistons,BB Stage 2 Valve body, MTCM, Ported Eagle Heads, PWR Cam Fr-219 219/226, N2O, Ported Thottle Body, ETC ETC
    monty1269's Avatar
    Aug 2005
    I went under the car to take care of a rattling exhaust issue... Put it up on ramps,... crawl under, and grabbed a handfull of metal sticking out of the inside edge of the tire!! OUCH!!! Needless to say, I pulled the wheels off the car and went back to stock tires. Yippie. Guess I can run down the 1/4 without the extra heavy Foose wheels.....Really changes the look/feel of the car.
    Just REALLY odd the location of that wear-pattern. I looked in the wheel-well to see if there was any rubbing, and *I* didn't see anything.
    monty1269's Avatar
    Aug 2005
    Rear....
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by monty1269 View Post
    Rear....
    That's what I thought. So here's what happens with our rear suspensions when your lower them. It automatically toes in. And what was happening IMO is it's scrubbing off the tire towards the inside and literally tore the inside edge off. You can see the wear starting from the outside working inwards.
    BTW, I just completely ruined a brand new set of F1's in exactly this manner. Mine was more extreme then this, but identical.
    boggart's Avatar
    Pittsburg, KS
    Looks like an alignment issue to me. (Agreeing with CAM)
    monty1269's Avatar
    Aug 2005
    Yeah......that's what *I* figured. BUT! I didnt have this problem before. (when I had the 20's on there)...Plus it's been dropped for almost 2 years....Maybe something went 'south' on it? hhhhmmmm... Cant really remember when the last time I had the alignment done.... I guess it has been a while.
    monty1269's Avatar
    Aug 2005
    I just went out and looked...nothing seems out of the ordinary back there... Things seems straight...no missing bolts or bent arms...
    Fargo59's Avatar
    yeah, those tires were well past due for the scrap pile. adding the alignment, and horsepower, and presto. there goes a tire...
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    When I ran the stock bushes, even though I had a fair amount of (-) camber. My wear was pretty good. But the negative camber ended up giving me other acceleration issues so I decided to install the offset bushes. Well that cleared up my camber isssue and the other problem I was having. But I had the toe way off. I knew I did, but didn't think it was all that bad. Man, was I way fricking wrong. I ruined a complete set of F1's dealing with it all within a couple thousand miles. It could be your traction arm bushes and upper control arm bushes are wipped out.
    EDIT: I forgot to add something. Under acceleration, the rear squats and this causes the geometry to toe in worse. So even if you haven't been spinning the tires but have been doing very hard launchs, it'll wear them out sooner. So that little blurd about the cam causing the problem is not really that far off.
    stitchmonkey's Avatar
    stitchmonkey is offline What's up Doc? Who's drivin this thing?
    Feb 2007
    It rubs the lotion on it's skin, or else it gets the hose again!
    When I had the Teins installed it dropped the car a good 2" I had the Pedders offset camber bushing kit "I think thats what it's called" Alignments perfect now toe and camber.
    monty1269's Avatar
    Aug 2005
    ME?!? Hard Launch??? ALWAYS!!
    Stitch- Got more info on that?? pita to install? cost? PM if you want...
    monty1269's Avatar
    Aug 2005
    FYI-
    295 / 35 / 22....... Trying to find replacments for the rear. Any suggestions?? Anyone know about these Nitto NT420's??? $100(each) cheaper than the Scorpions.
