Is the V8 rear shock heavier than the V6?
I have a Charger SE. Is the RT rear shock heavier/stiffer than the rear shock
on the SE? Same question with the front. By the way, what do we have up front? Is it a strut? A shock inside a spring? What exactly is this front set up?
The rear is obviously an independent spring with an independent shock.
But I do not know what the front unit is called.
- You may not post replies
- You may not edit your posts
Forum Rules
