Results 1 to 15 of 16
    Charger Fred's Avatar
    Charger Fred is offline 08 Charger
    Nov 2008
    Springfield VA
    TPMS and second set of wheels for a 2008
    I have a 2008 Charger and bought some chrome rims I am putting summer tires on. I want to keep my original wheels and tires for winter use. I found out if I set up the new wheels with a new set of TPMS sensors I have to have the car's TPMS system reprogrammed to recognize the new TPMS. Then if I switched back in the fall, the car's TPMS system would have to be reprogrammed again. Each reprogramming cost a $100 at the dealer! A service manager told me he would take the sensors out of the current wheels and have them put on the new rims and not have TPMS on the winter set. He said I have to be careful because if the TPMS sensors don't end back on the same wheel the cars TPMS would have to be reprogrammed.
    What do other owners with 2008 or later cars do with a second set of wheels? Surely, you guys up north must have run into this.
    Fred
    custom graphics, infinity kappa speakers, blue interior LEDs, Daytona wheels, Sumitomo HRT ZIII tires, Big Bully intake, LED halos in tails
    Ks Banana is offline Banned
    Feb 2009
    cheney, ks
    its not only on the 08,s its the human race out smarting ourselves again. most tire shops have a programmer to reset the Tpms and they dont charge no 100.00 to do it, takes about 10min at most. to be honest with you the TPMS is more trouble than its worth, i wish they offered it as a option only, i would have it deleted. Find you a good tire shop and work with them and they can take care of it, i believe you can get new Sensors at Orielly,s for 40.00 and get them programmed and have the cost 1 time. What i would do if it were me, but im not to smart either.
    Nightshade's Avatar
    Nightshade is offline LX Guru
    Kitchener, Ontariooooo
    Quote Originally Posted by Charger Fred View Post
    not true.
    Put the second set on, and drive he car.. the car will learn the new TPMS after a while.
    i had my winters put on and they wanted to tell me that it will cost another 80 to 'reprogram' the TPMS sensors... I called BS on it had them just mount them and then I left.. by the time I got home, the car had learned the new tpms and I didn't get a single beep for tire pressure (except when the front left was loosing air)..
    fargo59 confirmed that you just need to drive the car for a bit and it would learn it itself...
    Hemi Mag's Avatar
    Hemi Mag is offline Baba Booey
    Nov 2006
    Mississauga
    Yup I have 2 sets of factory rims summers/winters and it's the same thing, unbolt one set bolt the others up and take it for a ride around the block, good to go!! I have had tis setup for 2 years now with no issues.
    AC
    http://www.lxforums.com/board/signaturepics/sigpic12069_2.gif
    'When I was arrested I was dressed in black'
    _____________________________________
    Mods: Predator 93 CAI, Air Hammer, Eagle Mani, Stainless Works Long Tubes, JBA Catback, SRT8 suspension, Mopar Sways, REM Strut tower bar and Bumpsteer, Dual weave Grill, Daytona Chin and 20s, CSRT8 Diffuser, Kicker Sub, 6000K & 3500K HIDs, shaved letters, Old skool R/Ts, Hood Struts, 300C Handles & lower moldings, Two toned tails, BT Oil Catch and other goodies, Husky Liners, and Sirius Stilleto.
    13.5@105
    Jason84 is offline LX Padiwan
    Jul 2008
    Green Bay, WI
    I think you drive over 25 mph for about 15-20 minutes and they reprogram themselves.
    But you also have to watch out because 05-07 tpms sensors are diff from 08-09 ones.
    Nov 2008
    Springfield VA
    Quote Originally Posted by Nightshade View Post
    not true.
    That is what the tire store said. The service manager said you even had to reprogram after rotating your tires on a 2008.
    Fred
    Jul 2008
    Green Bay, WI
    Do you really care if it tells you which tire is low ? who cares if your tires are low you are probably going to recheck them anyways.
    dont worry about it as long as the stupid light is off who cares. Your car will still run
    Nightshade's Avatar
    Except that on the LX, you don't get to see what tire is low, you just get the idiot light.. even my 08 daytona is like that... but my 08 Avenger would give you the tire pressure in each wheel separately.. I can see that being an issue if you care what tire is going low..
    Idiot light is good enough for me though.. it comes on and you can tell what tire it is by looking.. if you are gonna fill one, you should be checking them all anyhow. (tire pump is already running so why not eh?)
    dumpster's Avatar
    dumpster is offline rock and rolla
    Feb 2007
    zion, illstate
    my 300 lets me know on the dash what each tire pressure is but on non evic cars its just the light
    Nightshade's Avatar
    Quote Originally Posted by dumpster View Post
    I have EVIC, but no individual display of what tire is low... Was surprised that it didn't have that since even the crappy avenger I had displayed tire pressure on each wheel..
    but if it requires reprogramming at every rotation or tire change.. glad I have the basic TPMS..
    But in response to the OP.. 100 bucks to reprogram is nothing more than a cash grab.. have somewhere else do it.. or find someone with a starscan and buy them a case of beer to do it for ya.
    Nov 2008
    Springfield VA
    Does anyone know if I can use a second set of TMPS on a 2008 and not have to reprogram?
    How hard is it to disable just that light?
    Fred
    Jul 2008
    Green Bay, WI
    there is lots of people that do... look on charger forums.. there is a few tpms writeups.
    One guy took his tpms sensors and made a pvc canister and filled it with air and let it sit in the trunk.
    Nov 2008
    Springfield VA
    Quote Originally Posted by Jason84 View Post
    Thanks, I have been looking there as well. But I am not any less confused.
    Fred
    Jul 2008
    Green Bay, WI
    If its really that bad of a deal just do it If it doesnt work. then pay the money or deal with the light.
    It all started with that stupid bridgestone or firestone huge tire recall(think it was the SUV tire?).... It wasnt actually the tires it was the air pressure in the tires. So they started this law thinking it will save lives I think its all cars made after a certian date in 06 or 07 must have tpms sensors.
    So for that reason most legit shops can also charge extra for working on cars with tpms sensors most shops will have a hidden sign somewhere saying they can charge more if your car is equipped with it. All you need is to find a good dealer with a cool mechanic that will just do it for nothing if its that big of a deal to you.
    Nov 2008
    Springfield VA
    I have never found out what works and doesn't work for my vehicle so I will have the tire store where I am getting my new tires swap two of my stock wheels and see if the TPMS adjusts to it.
    If the TPMS does not adjust to swapping the location of two wheels then I will know I either need to have the current TPMS used with the new rims and go back to the same location or have the TPMS reprogrammed.
    Fred
