Results 1 to 7 of 7
    DCPDGUY's Avatar
    DCPDGUY is offline Amish LX'er
    LI, NY
    Toyo Proxes T1R 255-35R20 285-30R20
    I can get a smoking deal on this setup but to me seems too small of a profile. The seller swears they will work but of course he would say that. Would be mounted on a set of Chally Repos that I have had my eye on. I plan on lowering the Charger so would this help in that department?
    Any help would be appreciated.
    Chris
    xevilpetex's Avatar
    xevilpetex is offline Terror of the Northeast
    Long Island, NY
    They will probably be too low of a profile for you for driving on the street. It will physically make the car lower, but you will have more wheel gap and if you drop the suspension then you will have very little clearence between the road and the bottom of the car.
    MOL SRT-8's Avatar
    MOL SRT-8 is online now SHOW & PERFORMANCE
    Dec 2006
    SAN DIEGO, CA
    those are pretty short sidewalls for a 20" wheel with fender well as large as ours.
    WWW.SHOWANDPERFORMANCE.COM
    SoCalLX
    Congratuation Del Worsham
    2011 Top Fuel Champion
    mexi's Avatar
    mexi is offline thats my sippy cup!
    Feb 2006
    N Misssisspi . Memphis TN
    its a 27in tall tire. it will work just an inch shorter than a stock tire
    mopar 11
    Corsa Hotchkis ...so far.
    89grand's Avatar
    89grand is offline LX Guru
    Phoenix, AZ
    Quote Originally Posted by mexi View Post
    its a 27" tall tire. it will work just an inch shorter than a stock tire
    I wouldn't recommend it. The 255/35/20 is only 27" tall and the 285/30/20 is only 26.7" tall.
    The stock tires are 28.6" tall so the front tires would be nearly 2" shorter and the the rear tires would be a full 2" shorter.
    2000 Jeep Wrangler
    1966 Dodge Monaco 500
    DCPDGUY's Avatar
    LI, NY
    Thanks for the info I decided to pass on them. Mine is a daily driver so the lack of side wall was the determinintg factor. But at 200 for the set it was hard.
    mexi's Avatar
    Feb 2006
    i would have bought them for that.lol
    mopar 11
