Results 1 to 8 of 8
    T4O6O2L's Avatar
    T4O6O2L is offline Gokyu
    May 2005
    Shiloh, Illinois
    Tires to fit my SXT
    Will these fit ok on the stock wheels: 235/65/17
    http://www.tirerack.com/tires/tires....omCompare1=yes
    Steve S.'s Avatar
    Steve S. is offline LX Padiwan
    Atlanta, GA
    They should fit on the stock rims, but they are taller than the 3% variance that tire manufacturers recommend. The stock tires are 28" and these are 29.1".
    T4O6O2L's Avatar
    May 2005
    Shiloh, Illinois
    Hmmm.
    I though the stock tires were also 65s, maybe im just not very knowledgable on this issue. Wouldnt these tires be wider with the same height?
    T4O6O2L's Avatar
    May 2005
    Shiloh, Illinois
    I guess maybe I answered my own question. Suggestions?
    So what tires are good and will last and will fit my sxt stock?
    deuceroadster2 is offline LX Newbie
    Lexington, KY
    As your tire gets wider it will also get taller(as long as your aspect ratio stays the same) in your case the 65 series.
    As an example: A P2256016 and a P2355516 are roughly the same height but the P235 is wider.
    If you need anymore help e-mail me or PM me. I did this for a living for a long time. If I can do it anybody can.
    madjeff22's Avatar
    madjeff22 is offline "MAD HEMI"
    May 2005
    San Antonio TX
    Deuce (or anyone else that knows the answer),
    If you get wider tires (P235) will you also need to get new rims?
    2008 Brilliant Black Crystal Pearl Coat Charger SE Plus
    1. MOPAR CAI
    Lexington, KY
    madjeff22:
    Not always. Every tire size has a range of rim sizes that it will fit on. You can usually go up one or two sizes without any problem. If the change is drastic then there exists the possibility of needing new rims to accomodate the wider tire.
    For handling purposes you should always try to go with the widest rim that your chosen tire size will fit onto.
    Deuce
    LtlDad's Avatar
    LtlDad is offline LX Padiwan
    Nov 2004
    OC, CA
    As FYI, I just put the 18" RT rims on my SXT w/ 255/55/18 tires and there does not seem to be any problems. Also have the Eibach Prokit (1 1/4" drop).
