Hey all,
I've been looking at/thinking about getting new wheels and tires for my mag. The question I have is, can I move the tire pressure monitors from the stock rims over to the replacements? Or do I need to buy new ones?
Thanks.
Hey all,
Thanks.
2007 Magnum SRT8 Steel Blue Metallic/Option groups 1,2,3/Roof Rack/Sirius/Everything but VES
2006 Magnum R/T - GONE!
You can move them over. It might be better just to buy new ones...
the cost of breaking down your wheels and tires just to get them out might be the same as getting new ones...
just my 2 cents...
Thank you Bigal470
Like Noid said, you can move them over.
But...they are $43 each from the dealer...ouch!!!
2006 Charger R/T R&T Black..SRT8 stuff/JBA stuff
2005 Magnum R/T inferno red-now in magnum heaven
1966 Galaxie fastback-C6 w/460BB..sold, but not forgotten
if you contact one of the vendors on here.. I think it is the mopar supercenter they sell them cheaper than the 43 each...
Thank you Bigal470
ok what do tire pressure monitors do? does it only check the tire pressure? where does it show up? on the odometer? because i dont have the top of the line model so is there any way to get this?
If you do not have the TPS on your car... then you will not need these...
they monitor the pressure of air in the tire and once it dips below 25lbs... a light comes on the dash to let you know..
Thank you Bigal470
I bought a set for $37 a piece from a local dealer. I'd suggest shopping around.
Also, please do remember that not every aftermarket wheel will be suitable for use with the tire pressure monitors! There has to be enough clearance and the valve stem has to be angled correctly to avoid damage from road hazards such as potholes and debris we all occasionally hit.
Certain styles of the MHT wheels such as the Foose Nitrous actually have two valve stem holes on each wheel. The tire pressure monitors go in the inside hole and it's really a good way to go.
will these work if I have 265/35/22 I am worried about having enough room behind the rim and tire.
Mods List: -- 2006 R/T Hemi, 3-10 Diamond Audio Subs, Kenwood DDX8017, Dolby Surround with Diamond tweets, 4inch and 6inch doors and dash, 2-Diamond Audio Amps, 22x9.5 Foose Nitrous Chrome Wheels - Pirelli 265/35/22 tires - Eibach Pro Kit- Bassani SS exhaust.
The sensors go inside the wheel. They do not get mounted outside of the tire.
Thank you Bigal470
Sorry to hijack the thread, but I am getting a set of SRT8 wheels/tires that have the sensors. My car (05' Magnum SXT) was not set up for them. What do I need to do to get them to work with my car?
Budder.. I have two valve stem holes.. would you recommend putting them on the inside lip or in the valve hold that is in the center of the deep dish?
five points..
trust me you dont even want them.. the tps system is gay.. i have so many issues with mine i'm not even gonna get into it.. plus.. they wont work if your car doesnt have tps anyway. not worth the hassle
