Results 1 to 11 of 11
    blackmagnum06's Avatar
    blackmagnum06 is offline me la mames en reversa cabron!!!
    southern ca
    Sway Bar Differences?
    I Wanted To Know If The Hotchkis/st Sway Bars Are More Stiffer Then The Srt Sway Bars. Or Is It The Same?
    Let Me Know
    formerice's Avatar
    formerice is offline LX Guru
    Dec 2004
    maine usa
    I'm 99% sure the Hotchkis are stiffer. SRT and RT are the same, but the struts are different.
    Super T's Avatar
    Aurora, IL
    Correct, Hotchkis are much stiffer than stock RT or SRT. ST and Eibach don't publish their stiffness numbers, while Hotchkis publishes the % difference over stock. 30-something % stiffer in front and like 150% stiffer in rear. That's why I chose them over the other guys, they're willing to tell you how they perform.
    Mighty Noid's Avatar
    Mighty Noid is offline time to paint the car soon!!!
    Aug 2005
    SoCal
    Read this...
    It is on the Charger forum...
    http://www.chargerforums.com/forums/...ight=sway+bars
    Thank you Bigal470
    2005rtmag is offline 2005rtmag
    Wilmington, N.C.
    The only sway bar I've ever had that broke was the factory hollow 5/8" bar on the rear of my 95 Mark VIII Lincoln. I replaced it with a solid 1 1/8" Addco bar. Tremendous difference in the handling and did not oversteer.
    The ST bars are solid.
    Addco makes a hollow rear bar for our cars. It's about $160 from Summit. It may be all you need to balance the handling. Go to their web site and look up Chrysler 300.
    Charg-um's Avatar
    Charg-um is offline <---- M for Mwaa Haa Haa
    May 2006
    South Fl, near the beach.
    Sway bars are the easiest mod to feel the difference with I think.
    First mod I always do.
    Painter Paul.
    #001 "The original"
    Sponsored by High Horse Performance Inc and Billet Tech
    Who wants to be a Charg-um ? :
    Super T's Avatar
    Aurora, IL
    ^^ I agree, they make a killer difference in handling.
    Ali"i 300C's Avatar
    Ali"i 300C is offline Ali&quot;i 300C
    Apr 2006
    Weikele, Oahu, Hawaii
    Read somewhere that the police version sways are much stiffer, and might be a cheaper fix...anyone have details?
    ..........my bad, just read the link above that covers the cop version. Anyone done that?
    lmbcfls is offline LX Padiwan
    Diameter does not tell the entite story. Hollow bars are typically "stiffer" than solid bars -- a hollow bar will give the same benefit as a larger solid bar. The length of the bar between the outside (outboard) holes is critical - some bars offer several mounting points for the end links, to allow for varying lengths (which allows for varying the bar's stiffness), and (at least in theory) dialing in the desired oversteer/understeer characteristics. A shorter bar will be stiffer than a longer one, with the same diameter.
    06 MSRT. KW, Hotchkis, and REM. Predator, Corsa, and AFE. No more Ram Heads -- Flying Skulls instead (on BT badge, sills, center caps, and underhood; and on Jinah's mats and console cover). Entirely shaved, no rear wiper. SRT door pulls, SRT pedals, Lloyd's HEMI luggage mat, leather shift bezel and matched knob, dash kit matching factory trim, Mopar IPOD, hardwired V1, Mopar hidden hitch, yada yada
    critten1's Avatar
    critten1 is offline LX Newbie
    Jan 2007
    Spring, TX
    Quote Originally Posted by Ali"i 300C View Post
    This was done a few months back. There was a pretty extensive discussion on this. Even measurements were taken of the widths of the different swaybars.
    Torred Daytona 1633
    Mods: Royal Purple
    , AFE Stage II CAI
    bradkaye's Avatar
    bradkaye is offline LX Padiwan
    Atlanta, GA
    I just know it's a night and day difference, especially with the rear sway. I did the SRT upgrade along with my front swaybar 6 months after I got the car and loved that performance upgrade. 2 years later, I finally ponied up the cash to have the rear installed.
    I'm kinda glad I did the rear swaybar at a different time, because it was amazing to feel, with all other things being equal, (shocks, struts, springs, tires,) it totally transformed the peformance of the car. With the Hotchkis addition, you're truly cornering at the limits of the tires and I'm all too aware of the 420 treadwear rating of my Toyo's. My ESP engages more now than ever, (even when it's 1/3 disabled,) because the car just holds.. holds... holds until the tires let loose.
    Steering input becomes much more precise, it's hard to explain, but I can feel the rear of the car respond to small steering movements in a turn now.
    The only downside is that it really makes for a rough ride on seamed concrete. Living in Georgia where I've got mostly blacktop, it's not too much of an issue, but if I were living in Michigan I would probably opt not to go for this level of performance on a daily driver... it'll shake your fillings loose.
    Aw heck. I'd probably rather have loose fillings than slushy suspension.
    'His'
    2006 Magnum SRT8 -Inferno Red, Diablo Tuner, DC Strut Bar, 'Radiator Cap' Mod
    'Hers'
