Results 1 to 15 of 22
    Jun 2005
    IN THE ETHER
    Suspension Measurements
    Alright LXers. Time to bust out your tape measures. I need some help. I need to get some suspension measurements from your vehicles. I need them from both a stock Magnum RT and stock Magnum SRT with no suspension mods. I need two measurements . Plus, I would like them in millimeters(Its easier to do math with millimeters),
    First measurement:
    I need the measurement from the the top of the wheel arch to the bottom of the center cap. Just like below.
    Second measurement:
    I need the measurement from the bottom of the head of the rear shock bolt to the center of the bolt on the bottom suspension arm.
    I need these measurement with an empty load in the back. I am doing a suspension mod and I need these measurements. I need them mostly from a Magnum SRT model.
    Once I finish this mod, I will write up a thread on what I did complete with pictures.
    Thanks for your help
    Jose
    PEACE OUT YO!!!
    Mighty Noid's Avatar
    Mighty Noid is online now time to paint the car soon!!!
    Aug 2005
    SoCal
    You may find a few at Beach Burger tomorrow night...
    Thank you Bigal470
    ephines's Avatar
    ephines is online now Looking for something new.
    Mar 2006
    Bremerton, Wash.
    Courious on what is your plan?
    Coors Light Silver 2005 Magnum RT
    MODs MyGig-Nav, 22Elite console cover, Leather door pulls, 10" Alpine Type E Sub in a ME Design enclosure w/ Alphasonik Amp, 3M Invisi-bra, Mopar CAI, 09 replica Challenger Wheels, Mopar Lowering Springs/Eibach Shock Hotchkis Sway suspension.
    Jun 2005
    IN THE ETHER
    Quote Originally Posted by Mighty Noid View Post
    Thats what I was thinking but unfortunately, I cant make it today. Can someone take these measurements? Its not hard to do.
    Thanks
    Jose
    BTW. T dont want to do a Randy.
    Im trying to mod some SRT rear shocks to work with the MOPAR drop springs. Im trying to get another 1/2 drop from the Nivomat shock. I may have found a way but I need the stock ride height measurement from an SRT to work as my base measurement.
    PEACE OUT YO!!!
    Jun 2005
    IN THE ETHER
    I will give myself one bump only.
    PEACE OUT YO!!!
    fnkychkn's Avatar
    greasy cardboard box
    i'll bump you and add a quote from FSM.
    CURB HEIGHT MEASUREMENT
    The wheel alignment is to be checked and all alignment adjustments made with the vehicle at its required curb height specification.
    Vehicle height is to be checked with the vehicle on a flat, level surface, preferably a vehicle alignment rack. The tires are to be inflated to the recommended pressure. All tires are to be the same size as standard equipment. Vehicle height is checked with the fuel tank full of fuel, and no passenger or luggage compartment load.
    Vehicle height is not adjustable. If the measurement is not within specifications, inspect the vehicle for bent or weak suspension components. Compare the parts tag on the suspect coil spring(s) to the parts book and the vehicle sales code, checking for a match. Once removed from the vehicle, compare the coil spring height to a correct new or known good coil spring. The heights should vary if the suspect spring is weak.
    NOTE: When measuring, the maximum left-to-right differential is not to exceed 12.5 mm (0.5 in.).
    1. Front – On each side of the vehicle, measure the distance (2) from the frame rail just behind the engine cradle rear mount (1) to the floor or alignment rack/lift runway surface. It may be necessary to measure to the bottom of a straight edge, placed from lift runway to runway, to get an accurate measurement.
    2. Rear – On each side of the vehicle, measure the distance (2) from the travel limiter (1) attached to the front rear crossmember mount bushing to the floor or alignment rack/lift runway surface. It may be necessary to measure to the bottom of a straight edge, placed from lift runway to runway, to get an accurate measurement.
    3. Compare the measurements to the specifications listed in the following Curb Height Specifications chart. CURB HEIGHT SPECIFICATIONS
      MODEL / FRONT / REAR
    4. ALL-WHEEL-DRIVE / 352 mm ± 10 mm / 308 mm ± 10 mm (13.85 in. ± 0.39 in / 12.13 in. ± 0.39 in).
    5. REAR-WHEEL-DRIVE / 328 mm ± 10 mm / 296 mm ± 10 mm (12.91 in. ± 0.39 in / 11.65 in. ± 0.39 in).
    6. SRT8 / 321 mm ± 12 mm / 290 mm ± 12 mm (12.64 in. ± 0.47 in / 11.42 in. ± 0.47 in).
    7. POLICE PACKAGE (Without Equipment*) / 345 mm ± 10 mm / 315 mm ± 10 mm (13.58 in. ± 0.39 in / 12.40 in. ± 0.39 in) * NOTE: Police Package height specifications given are for settled vehicles without additional standard police equipment added. Once police equipment is added, estimated at 520 lbs. (400 lbs. for Magnum with 5.7L), vehicles should meet normal REAR-WHEEL-DRIVE specifications as listed above.
    Jun 2005
    IN THE ETHER
    Thanks fnky. You're the best!
    I might be able to incorporate these numbers in my calcs.
    PEACE OUT YO!!!
    since your shocks don't look like my nivomats from the tow package, it may lower just fine with the spring change.
    Jun 2005
    IN THE ETHER
    Wow!! I guess no one owns a tape measure.
    I'll just have to ask the first SRT owner I see on the road and ask them if I can measure their car.
    PEACE OUT YO!!!
    Jun 2005
    IN THE ETHER
    Quote Originally Posted by 65standard View Post
    These are the shocks I just got. The rears are SRT nivomats. The fronts are used stock RT shocks(I wont be using those)
    PEACE OUT YO!!!
    Rob@WretchedMS's Avatar
    Rob@WretchedMS is offline Evil Pedders Guy Since 06
    Jan 2007
    CT/MA
    Checking Ride Heights,
    http://westfield-et.com/article_info.php?articles_id=2
    Most aftermarket manufacturers are going to a 'Rim to Guard' measurement for measuring ride heights.
    This is a much more accurate way to check the heights due to variances in tires.
    A listing of ride heights with rim diameter is best.
    what are you thinking of doing to lower your car and use nivomats? i tried to do this too, along with a few others. no success and i am a fabricator.
    Jan 2007
    CT/MA
    The Nivomats are evil, We have had success with non nivomat cars, but the problems that the nivomat's have given us will be old news soon.
    We should have our dampers available with our existing spring combinations in Late Oct, Early Nov.
    I've found no way around the nivomat settings.
    Quote Originally Posted by Rob@Westfield-ET View Post
    The Nivomats are evil....I've found no way around the nivomat settings.
    me neither. i have even shortened the nivomats 2" to try to lower my car with the sportlines and that didn't work. the shocks just pumped up to the limit trying to make up for the shorter length. the whole car was riding just on the pumped up shocks. the ride was horrible.
    moving the shock mounts lower didn't work either.
    so what are you thinking here????
    Jun 2005
    IN THE ETHER
    Well. That's what I was thinking. I was going to shorten the collar spacer on top of the shock. I was going to remove about 3/8 th inch so that the top shock mount would drop. Since the shocks are supposedly set for a specific length, the drop of 3/8th inch to 1/2 inch would be fine. This is my theory though it may not be right.
    I remember seeing a thread on this forum about the Cadillac STS guys doing the same thing with thier nivomats and have success with the drop springs for thier cars.
    Am I doomed for failure? Please advise
    Jose
    PEACE OUT YO!!!
