Attempted to lower the rear of the magnum, and one of the lugs just spins with the stud. How do you get the lug off? Would this be covered under warranty? Plllllease help!!
Question is who was the clown that last worked on the wheel, needs his nuts adjusted. I would expect the last person to have touched the wheel is going to pick-up the repair bill.
Put the other 4 back on and get the car back to the place that last had the wheel off...![]()
Sux, man - good luck...
Brilliant Black '06 Magnum SRT8 • FRI 'Street' heads, ported intake & Tomahawk cam • MagnaFlow HF cats • B&B cat-back • B&G Stage II
The Iron Mistress Galleries
R.I.P. Dave...
Probably not stripped, just the chrome cap thing on the nut is spinning, try tapping a 13/16ths ( or 21mm ) socket on carefully and undo. This is caused by someone using the wrong size socket usually 7/8ths...
Dodge Magnum RT AWD MDH=Jan 19th 2005 7-8pm
Tow package, Midnight Blue, Painted spoiler body colour, Auto headlights, HID lows, Fogs on with Hi beams, SC flash with custom tranny and 91 tune, RER MyGig installed, Tranzformer, Resonators deleted, Custom Stainless intake.
160,000km driven very hard, repairs include replaced front brake rotors and pads $200, rear pads$, ebrake shoes, all 4 tie rod ends $50ea (only 1 was loose), front sway bar rubber bushings $25(first thing to check if front is clunky); 3m refinished headlights WOW $30, 4 sets of tires, 2 tranny filter and flushes,
I replaced all my "chrome capped" lugnuts, they are CRAP!
An embarassed Tech at America's (Discount) Tire knows I am always watching, he consoled me and installed REAL Plated lugnuts for like a buck a piece, less than their cost.
An over 40 victim of fate.
'8R'05 Magnum RT Midnight Blue Pearl
KW V 2 , Hotchkiss Sway Bars, CF Airhammer intake,T Rex Billet Grille, Body color Airtab Vortex Generators, Chromed stock 18's BFG KDW 255/55/18 Tires,Avon splash guards, Gibson Performance Stainless SteelHeaders, GibsonCat back, SC 91 Performance tune.
Hi Flo Cats
We have the right size socket on it. .we can see it spinning, by using a hand socket. I bought the car outta state, so I cant take it back to that dealer.
you'll have to drill it out. drill the center of the stud. start small and keep going bigger untill you've drilled the stud enough that the nut will no longer be holding the wheel. the trick is to make sure you hit dead center of the stud and go in straight.
EDIT: if the stud is not spinning and it's just stripped, you can remove the rest of the nuts and pry on the backside of the wheel while using an impact wrench to remove the stripped one.
good luck.
That sucks. My wife's cousin had that happen to him in his 67 Barracuda (transplanted 340 6 pack). He heard a pop and then the wheel starting shaking. He pulled over and saw that one of the studs broke. When he went to take the wheel off, he stripped one of the lugs!
"Walkin' the thin white line on this smiling road. 40 days, I've been all alone. Draggin' my heart all across this world. I got 100 miles to go before I get back to see my girl. Aint got nothing, I got nothing to lose. I keep walking away these blues. The cup is broken, but it's half full. I got 100 miles to go before I get back to see my girl."
100 Mile Blues - Scott Keeton and The Deviants
Worse, some late 60s early 70s Mopars had left hand lugs on one side!!! Know how many you can break off before you figure that out as a youth?
Don
yep, you get in the habit of licking your finger and wiping it on the end of the stud to reveal the tell-tale "L".Originally Posted by GasGunR
Thanx fnky. I'm gunna give the impact idea a try. If not, ill just drill it. Thanks alot
I'm in the same boat with my lugnuts.Took them to discount tire and they can't get them off.
'07 Magnum RT RWD Steel Blue with Road & Track package, NC-SXT silver honeycomb grill, 20" Foose Nitrous Chromes
Other Rides
'01 BMW Z3 2.5i Roadster
Watercrafts:
'97 Seadoo GTX - Hydroturf matting mod
'05 Crownline 202 BR with duoprop
Misc Toys
2010 Wildcat 31TS 5th Wheel
The last time I refused a beer I didn't understand the question.
I bet yours are spinning the chrome cap on the nut itself, check my other post aboveOriginally Posted by SeadooSandi
They really did left-hand lugs??? WHY?? I mean, if you do a centerlug race wheel, then yeah, it's necessary so it self-tightens... but on a multi-stud wheel, I say again, WHY??
