Results 1 to 4 of 4
    Husker's Avatar
    Husker is offline AG Strek
    Nebraska
    Strange wear pattern on back tires..
    So as I was having the rear tires replaced today the shop pointed out that the rear had a very strange wear pattern. The inside of the thread was down to the cords while the outside had good thread left..
    I always keep my tires at 32 psi ( 245/45/20, stock RS-A). But I wonder if this could be something from hitting the dear last fall...could it have screwed up my over all alignment????? Help me experts
    Husker
    05 Red Inferno Magnum SXT-Traded
    05 Red Inferno Magnum R/T- Traded
    06 Silver 300C SRT8 RWHP 371 RWTQ 374
    Options I,II Sunroof,Side Curtain AirBags BIG HEMI
    tank8289 is offline Supporting Vendor
    Jun 2007
    West Milford, NJ
    Well the rears don't have adjustments as i remember. My camber is off pretty badly to, but not to the point where its wearing out tires. Couple of people were supposed to be trying aftermarket kits to adjust camber, maybe someone can chime in.
    392 Stroker, Builder Bill TC, Builder Bill tranny, LXAS LVLI Tcase, Novi 1500 10.5psi, 150 shot of nitrous, tuned by Josh @ HHP
    sublime1365's Avatar
    sublime1365 is offline Dodgezilla!
    Jun 2007
    Phoenix, Arizona
    As a suspension guy, the camber is certainly off with that kind of wear... the tire is tilting inward at the top for that kind of wear... something may be bent. On cars with no adjustments its tough. I remember having to sometimes slot strut holes and use shims and all kinds of wierd stuff depending on the car... but there really isnt any guarantee it will hold the alignment if you could adust it. You certainly need to do something though.. tires are not cheap. Keep us posted.
    2007 Charger Daytona R/T - Sublime #1365
    Bright Freakin Green..
    Super-Duper Clean..
    Pretty Darn Fast..
    Really Freakin Loud..
    Fun as Hell...
    Mar 2008
    I lowered my car 2" and have some negative camber at the rear wheels. I do not have abnormal wear. The toe-in adjustment being off can cause some pretty severe inside tire wear. I'd have that checked also.
    PPP stage 3 heads, Howards cam 219/227 .600/.575 112 +4, ported 6.1 intake, MMPG 85mm throttle body, MSD "Blaster" coils, JBA headers & mids, Corsa exhaust, Paramount "Dominator" torque converter & stage 2 valve body, BC Racing coilovers, Eibach sways, BWoody links, Razorsedge brace, 226mm Getrag 3.91 LSD, Wilwood "plus 2" big brake kit by TCE
