Results 1 to 5 of 5
    Arms's Avatar
    Arms is offline Traveler
    Oct 2008
    Riverside, CA
    Staggered on Factory 18's
    Anyone running staggered on factory 18" r/t in rims?
    Looking for stock in front and 255/55/18's on back, only need rear tires right now and thinking of putting bigger meats on back.
    THE KID's Avatar
    THE KID is offline aye mario it's me luigi
    Apr 2006
    milwaukie,or
    it would be higher in the back cause the sidewall would be thicker.
    Posted via LXFMobile
    Hal'sMag is offline Wax On - Wax Off
    Feb 2007
    L.A., Ca.
    I have that on mine now, and there's very little difference in tire height (radius), but it appears much larger due to the width.
    http://www.1010tires.com/TireSizeCal...?action=submit
    I also ran 235/65/18's in the rear when I got a flat out of town, and had no choice in tire selection. They added quite a bit in height, and a speedo reset was needed (Superchips or Diablo). That lower my RPM and I gained about .4 MPG highway. The 235/65/18 you run out of clearance at the front of the wheel well.
    Just a grocery getter!
    Arms's Avatar
    Oct 2008
    Riverside, CA
    Thanks Hal, do you have any pics?
    89grand's Avatar
    89grand is offline LX Guru
    Phoenix, AZ
    Quote Originally Posted by THE KID View Post
    Not much, those tires are fairly close in diameter.
    The stock 225/60/18 is 28.63" tall, a 255/55/18 is 29.04" tall. Only a .4" difference.
    2000 Jeep Wrangler
    1966 Dodge Monaco 500
