Results 1 to 8 of 8
    jt321 is offline LX Newbie
    Feb 2007
    Sportline Springs, bottoming out.
    Just got the springs installed on my 300 3.5. Running 265/30/22, i took the 4 rear isolators out(the rubber pads that the spring sits on). The problem im having is i think the rear shocks are bottoming out when i hit bumps?(i took the bumpstops off completely). Would buying shorter rear shocks cure this? Where would i get some?
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Quote Originally Posted by jt321 View Post
    As much I as want to give a smartass,sarcastic reply to this all I will say is you need Eibach Shocks as well......and put the isolators back in
    BFNY PERFORMANCE
    RIP My Friend
    elcobra44's Avatar
    elcobra44 is offline The times they are a changin...
    Feb 2006
    Batavia, IL
    You're not suppose to remove those isolators, but but instead cut about half an inch (I think) from them...
    Hemi31's Avatar
    Quote Originally Posted by elcobra44 View Post
    No...those are the bumpstops you cut a half inch from.....the isolater is the rubber between spring and body.
    BFNY PERFORMANCE
    RIP My Friend
    Mar 2008
    PUT THE ISOLATORS BACK IN! If your using stock shocks....Trim, then put the bump stops back in. If it's still too bouncy, replace the stock shocks with some quality performance dampers. I use the Eibach pro-dampers with my Sportline springs.
    PPP stage 3 heads, Howards cam 219/227 .600/.575 112 +4, ported 6.1 intake, MMPG 85mm throttle body, MSD "Blaster" coils, JBA headers & mids, Corsa exhaust, Paramount "Dominator" torque converter & stage 2 valve body, BC Racing coilovers, Eibach sways, BWoody links, Razorsedge brace, 226mm Getrag 3.91 LSD, Wilwood "plus 2" big brake kit by TCE
    bigal470 is offline LX Guru
    Nov 2006
    Oceanside, ca
    with my bags i dont run the bump stops inside the rear shocks and the axles hit body before the shocks bottom out so......you might be hitting body as well just a thought.......
    legendisdope's Avatar
    legendisdope is offline beastmode
    Sep 2008
    NORTHWEST
    lol why would u take the rubber isolaters out?? thats why, it probably sounds horrible when u ride. i got sportlines and the isolaters are on and i never bottom out.. i did once when i went over a bump wrong.. but thats all.
    Nov 2006
    Oceanside, ca
    I believe its a way of getting lower without cutting your springs...
    Quote Originally Posted by legendisdope View Post
