    HotInferno is offline LX Newbie
    Aug 2008
    Mobile, AL
    SE Wheel upgrade, tire question
    I recently bought a set of 18" 10 spoke R/T wheels for my SE.
    The current steels have 215/65 17's on the car from the factory.
    I am thinking of putting on 235/55 18's on the rims when I install.
    This is the size listed for the Daytona from the factory and when comparing sizes between the two they are extremely close on ride height. Will I have to have the car Star Scanned when I make this change? No TPMS on the car.
    Has anyone replaced their SE with this combo and had any rubbing issues? Looking at my car I don't forsee any on the outer side not sure on the inside.
    Thanks for any advice.
    345 RT's Avatar
    345 RT is offline LX Padiwan
    Hollywood, CA
    Quote Originally Posted by HotInferno View Post
    HotInfferno Dude,
    How much does your 17" steel wheel weight?
    THANKS
    SON
    First LX Forum Member To Hit The 12 second Mark In The 1/4 Mile With A 5.7L Motor. Period.
    12-16-05@L.A.C.R. Palmdale , 12.947@106.08 ET, 1.909 60ft, 10.770 1000ft and .002 RT at 50 degrees
    Mods at time of run-GSM NOVI-1200 S/C SYSTEM, Dyno-Teck Long-Tube Headers, High-Flow Cats, a Borla Cat-Back System, and 18 inch BFGoodrich Drag Radials. L.A.C.R. R.I.P
    SIMPLY SOUTHERN
    Charger Fred's Avatar
    Charger Fred is offline 08 Charger
    Nov 2008
    Springfield VA
    I put on 20 inch rims from a Daytona package on my SE. You should be able to find tires with a lower profile that are nearly the same diameter as you current tires. Keeping the diameter nearly the same means your speedometer won't be off and you won't need any reprogramming. I suggest you go to the car bible and check out his tire section.
    http://www.carbibles.com/tyre_bible_pg2.html. I believe a lot of people run 265 tires on their chargers with no rubbing problems. That is wider than you will be able to find most 18 inch tires in.
    Fred
    custom graphics, infinity kappa speakers, blue interior LEDs, Daytona wheels, Sumitomo HRT ZIII tires, Big Bully intake, LED halos in tails
