Results 1 to 9 of 9
    dodgerla's Avatar
    dodgerla is offline Its just a SIX
    May 2006
    LOS
    RT brakes Install ???
    Hi I have a V6 and wanted to upgrade my brakes but not spend thousands of $$$ so I bought some used RT brakes off of someone that upgraded to brembos. Im trying to decide if I should do the job myself or pay. I need any help or advice you guys can give me with replacing brake lines,rotors and calipers on the RT. I do have the service many but would like to hear from someone thats actually done it. My main concern is with bleeding the brakes. Is it O.K. to bleed them manually? Do you need to use locktite on any screws/bolts? Any help would be much appreciated.
    2006 CHARGER 3.5L 5speed+Diablo Predator 91oct. Tune+JBA c/c Headers+Magnaflow Dual Exhaust+Ported TB+K&N CAI+NOESP+Eibach Pro System Plus+R/T Brakes+POWER SLOT SLOTED & DRILLED ROTORS
    formerice's Avatar
    formerice is offline LX Guru
    Dec 2004
    maine usa
    While it should not be a big job, I'd be inclined to do it in a shop that I trusted, or the dealer. Bleeding the brakes would be easier with 2 people, also. I'm not sure that Loctite will work on the bolts because of the possible heat, though Neversieze might be a good idea if you live in the salt belt.
    dodgerla's Avatar
    May 2006
    LOS
    Does anyone know who carries stainless steel brake lines for the 5.7 and where to get them????
    Junior's Avatar
    Junior is offline LX Guru
    Phoenix
    Send a PM to Todd TCE.
    He includes stainless lines with his Wilwood kits - I'm not sure if the fittings are properly sized to work with the stock calipers, but perhaps.
    dodgerla's Avatar
    May 2006
    LOS
    Great write up on the brake job junior...Do you have any advice for my project. Thanks I PMed todd Ill see what he has available.
    Junior's Avatar
    Phoenix
    Quote Originally Posted by dodgerla View Post
    Thanks - yeah, I was going to link to that for you, but I see you found it. I don't know about the V6 setup, how it mounts, and if the 5.7 stuff is an easy swap.
    As for bleeding, you can sure do it manually. I never did it on my stock setup (I have Wilwoods now), and I don't recall where the bleeders are on the stockers, but there's no reason you can't do it manually.
    Hope that helps some.
    dodgerla's Avatar
    May 2006
    LOS
    Everything went on perfectly I had a local shop do the install all that is needed is R/T rotors,brake lines and calipers w/adapters. The brakes feel a world better than my stock brakes. Now that Im sure everything goes on good Ill be getting R1 rotors and russell brakelines(once they have them on stock part # 694060). Thanks for the help guys. Now its time for some
    MAGGUT's Avatar
    MAGGUT is offline LX Padiwan
    Lacombe, AB
    You say that calipers w/ adapters are needed.... Is this adapter just the stock caliper mount from a V8 car? Or is it an aftermarket piece?
    dodgerla's Avatar
    May 2006
    LOS
    Yes stock R/T caliper mount.
