Correct my understanding if I’m way off base.
Backspace is expressed in inches
Offset is expressed in millimeters
Positive offset is when the mounting hub pad is outside the centerline of the rim width.
Negative offset is when the mounting hub pad is inside the centerline of the rim width.
Example: 17x10” with an offset = +18mm, What is the Backspace?
Backspace = Offset (converted to inches) + (Rim Width/2)
Backspace = (+18mm/25.4mm/in) + (10in/2)
Backspace = 0.709in + 5in
Backspace = 5.709 inches
Terry
Old Skool
