Relocating front cradle for bias adjustment
Recently I did a pre-check roadtest for evaluation, and found a drift to the right. Everthing looked ok. I am aware of the bulletin on relocating the front cradle. So we loosened the motor mounts, supported the ending, then loosened the cradle bolts, and the cradle barely moved, and basically made no changes. Did I miss a step? Have others had success with this method?
thanks
mike
Here is the bulletin:
NUMBER: 02-004-07
GROUP: Suspension
DATE: October 3, 2007
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 02-002-05, DATED MARCH 12, 2005, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDES REVISED REAR WHEEL DRIVE (RWD) SPECIFICATIONS, ADDITIONAL SPECIFICATIONS FOR SRT AND ADDITIONAL MODEL YEARS.
SUBJECT:
Right/** Left** Lead Revised Alignment Specifications
OVERVIEW:
This bulletin involves adjusting the alignment to revised specifications.
MODELS:
2005 - **2008** (LX/LE) 300/Charger/Magnum
**2007 - 2008 L2 300 (China)**
SYMPTOM/CONDITION:
The vehicle operator states the vehicle leads to the right **or Left.**
DIAGNOSIS:
Drive the car on a FLAT road (**without crown or asphault ruts**). If the car tracks straight, the vehicle operator is experiencing crown sensitivity. If the vehicle tracks to the right **or left,** perform the Repair Procedure. Crown sensitivity can not be eliminated in all the cases.
NOTE :Before evaluating the vehicle, it is important to check the following:
1. Tire pressure - Adjust tire pressure (if necessary) in all four **tires** to the pressure stated on the door placard.
2. Tire size & type - Verify that all four tires are the same size and type.
3. **Ensure all luggage compartments are free of anything other than factory equipment.**
NOTE :When evaluating the vehicle, always drive the same road in both directions to get a feel for the effect of road crown, **rut wander** and cross wind.
QUIPMENT REQUIRED:
NOTE :**Ensure alignment equipment has been calibrated according to the Manufacturer's requirements.
NOTE :The vehicle will lead toward the side with the least positive caster. CROSS CASTER (left minus right) for front end alignment: (Relative to Individual caster, the RIGHT side will typically be higher than the LEFT side.)
^ RWD: - 1.0 degrees and no more than - 1.6 degrees.
^ AWD: - 0.6 degrees and no more than - 1.2 degrees.
^ SRT: - 0.0 degrees and no more than -1.2 degrees
NOTE :CROSS CAMBER (left minus right) for front end alignment: (Relative to individual camber, the LEFT side will typically be higher than the RIGHT.)
^ RWD & AWD: + 0.4 degrees**
^ SRT: + 0.30 degrees
NOTE :RIGHT LEAD CRADLE SHIFT (Produce more negative cross caster) Utilize the cradle shift method FIRST. When shifting the cradle, the passenger's side of the cradle will move forward in car and the driver's side will move rearward in car. The target torque for the cradle bolts are 175 N - m or 130 lbs - ft.
NOTE :LEFT LEAD CRADLE SHIFT (Produce less negative cross caster) Utilize the cradle shift method FIRST. When shifting the cradle, the driver's side of the cradle will move forward in car and the passenger's side will move rearward in car. The target torque for the cradle bolts are 175 N - m or 130 lbs - ft.
- You may not post replies
- You may not edit your posts
Forum Rules
