i installed the rear RE endlinks yesterday
The ID of the adaptor that mounts to the knuckle was incorrectly sized. I drilled out the hole to the correct size and after that everything mounted up well.
I did have to pop the brake caliper off to slide the rotor out a bit to get the bolt for the adaptor in position. This made the install a bit more involved then i expected it to be.
It was still not a difficult part to install and as far as i can tell it has firmed up the rear end nicely.
Hopefully the front endlinks will get here soon. They weren't available when i ordered them apparently so they just sent the rears for now.
