When I rotate my tires, will it screw up the tire pressure sensors? Does it matter which sensor is where? If I put my front driver tire on the rear passenger, does it matter? Thanks.
• Sweet Mango • Modern Mopar Muscle with an old school twist
Sponsored by:
• RDP Racing/Bullet Superchargers • Power Ported Performance • Universal Air Suspension • Stitchmonkey Embroidery •
No, it should not scew uo your sensors. They are limited range transmitters.
Custom Embroidered floor & truck mats
50% tint front 35% tint rear
SS grill & Radiator shourd
JBA SS headers
All LED's interior
100w Fogs & Hi beams
Modified air intake
Corsa Exhaust
HHP Hi-Flow Cats
Superchips FlashPaq
22"x9.5" Ace Mack's
Cross Drilled Rotors
Silver Steel Splash Guards
Hotchkis & KW VII
SRT8 Rear Spoiler
Clear Side Markers
CF front & rear chin spoilers
the base TPM system does not keep track of tire location. the premium TPM system uses three wheel well mounted transponders to keep track of tire location. neither system requires retraining after tire rotation.
\Originally Posted by fnkychkn
THREE wheel well sensors? how does it figure out the 4th wheel?
or is there 2 in the front, one in the back that picks up both rear wheel signals? (no engine to block radio transmission).
2006 Magnum SRT8 "HEMIWAGN"; HalfFast Performance built: Frank Racing Extreme Heads, Scudd Cam & Ported Intake; lafrad Tuned, Paramount Performance 4400TC & Valvebody. Best 1/4: 11.065 @ 123.54 MPH, 1.560 60' 3755lbs with driver
Thanks for the replies! Does the Daytona have the Premium or Base TPM?
Sponsored by:
the TPM sensors broadcast signal is received by WCM (wireless control module) in both base and premium systems. the wheel well mounted transponders are only to determine location. since the WCM knows the location of three of the wheels, it deduces that the fourth wheel is in the location without a transponder. also, on vehicles with full size spare, since the sensors broadcast more frequently when the wheels are turning, i knows which wheels are mounted on the car and which on is the spare (not turning).Originally Posted by hemiwagn
When putting on the bra, you have to cut three plastic rivets that hold the plastic wheel well to the front and screw in the anchors. While doing this, I noticed a module on each side, and I had no idea why they would place it there... Now it makes sense!
The service manual I got from here is handy, but it doesn't seem to cover this stuff!
2006 Magnum SRT8 - 11.85@117
Man that is cool.Originally Posted by fnkychkn
I think my wife uses the same technolog to track me and monitor if my wheel is turning or not.
