Results 1 to 10 of 10
    Invader's Avatar
    Invader is offline I R NUKE
    Apr 2006
    Acworth, GA
    Question to those who have lowered with Nivomats...
    Did the KWs drop into the Nivo mount, or did you have to go with SRT8 Nivos?
    I like the idea of going with the SRT8 ones, as I like the feature of them, just wondering if they'd fit or ..
    Anywho, TIA
    Invader's Avatar
    Apr 2006
    Acworth, GA
    Anyone?
    Ordering KWs does nothing for me if I can't install them in the rear....
    Do I need different rear shocks/dampers or will the KWs fit?
    TIA
    36 chambers's Avatar
    36 chambers is offline Banned
    ON A HOLLYWOOD SET NEAR U!!!!
    Kws Are Complete Set Up Front And Rear.the Nivo Cant Be Lowered In The Rear Anyway
    Invader's Avatar
    Apr 2006
    Acworth, GA
    Mabye I'm asking the wrong question.
    SRT8s have a lowered Nivo option.
    KWs are seperate spring and shock for rear applications (combined for front strut)
    Will the KW rear shock mount in the nivo lower mount or not I guess is the only question.
    TIA
    Yes They Both Have The Same Mounting Positions Uper And Lower!!!
    Invader's Avatar
    Apr 2006
    Acworth, GA
    Woot, TY.
    I think I misread your first response to say: You folks with Nivos can't lower your shiz.
    If I get it now, it says: Stock shocks and Nivos have the same mounts, as do the KWs, and If I wanted, I could go with SRT8 Nivos with the lowered spring in the rear? (I'm not slamming my ride, just going down about 1.5-2").
    Sorry for my confusion.
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Quote Originally Posted by Invader View Post
    Woot, TY.
    You didn't misread it.You cannot lower your car and use nivomats....they must be removed.
    BFNY PERFORMANCE
    RIP My Friend
    Invader's Avatar
    Apr 2006
    Acworth, GA
    /enter confusion again
    Since the SRT8s have a nivomat option (the SRT8s sit 1.5" lower than my AWD) and I'm only lowering my AWD by about 1.5", is it conceivable/feasible to use the SRT8 nivos in place of mine? They should level themselves out at the stock ride height of the SRT8, no?
    I understand fully how the nivos work, and I know I can't reuse mine due to the rear load being held by the shock instead of the spring at that point.
    boggart's Avatar
    Pittsburg, KS
    If you want to lower your AWD, you need to buy a coilover kit such as KW or ST, or go with airbag suspension. The Nivomats must go.
    RobAGD's Avatar
    Reston, Va
    You can try but I would just get a set of KW's or ST's to drop your car.
    the AWD cars or the mutant of the family
    -R
