Results 1 to 4 of 4
    510CHARGERRT is offline LX Newbie
    Jan 2006
    Question about lowering?
    Is it really neccessary to cut the rear bump stops when you lower your
    LX?
    JamminWagon's Avatar
    Cheyenne, WY
    The rears were such a bear that I forgot to cut mine. I have never bottomed out even when hauling about 100 extra pounds in the rear not includiing the 30# box, 20# sub and amps.
    Mar 2008
    It depends on how you lower your car. If you change the springs and keep the stock dampers, some springs will have you trim the bump stops in the rear, some won't. The best way to do it is to install new dampers when you install new springs.
    PPP stage 3 heads, Howards cam 219/227 .600/.575 112 +4, ported 6.1 intake, MMPG 85mm throttle body, MSD "Blaster" coils, JBA headers & mids, Corsa exhaust, Paramount "Dominator" torque converter & stage 2 valve body, BC Racing coilovers, Eibach sways, BWoody links, Razorsedge brace, 226mm Getrag 3.91 LSD, Wilwood "plus 2" big brake kit by TCE
    MikeEast's Avatar
    Ducktown, Georgia
    I didn't cut mine and it was ok for several years..
    "If you don't drag it once in a while, it ain't low enough."
    Mike
