Originally Posted by
cadzilla74
Hey, LtlDad, you've had your KDW's for a while now. Any updates you can share with us? I forget, are you'rs KDWS or KDW-2? These are probably what I want to put on my car and I was hoping to hear from folks who have had them a while about how well they are holding up and driving impressions over the long haul. Did you get your car flashed to accomodate the tire change or is the speedo change so small it's not worth the bother?
Wear seems to be okay, although I will double check w/ the rotation in about 2k more miles. Ride is better than the 17" rim (w/ Eiback kit), as I am not bottoming out as easily.
I plan on getting the 'flash' to a 245/55/20 in the StarScan, as it is the closest diameter to the 255/55/18. Since I have a SXT, the 18" rim is a big difference.
Not sure if/how the brakes are going to be effected, so far all seems okay.
2005 Mineral Gray SXT
HAS SOME STUFF...
