Results 1 to 4 of 4
    magnitude's Avatar
    magnitude is offline CenCalLX
    Burlingame, CA
    Proper alignment with Hotchkis springs
    I lowered my Mag with Hotchkis springs and the best my local tire shop could align camber is,
    LF -0.1
    RF -0.6
    LR 0.3
    RR -0.7
    I believe these are within acceptable range, but more neg camber than I'd like. Didn't think alignment would be so difficult with the (not that low) Hotchkis springs. Shouldn't I be able to get camber closer to normal without a camber kit?
    magnitude's Avatar
    Burlingame, CA
    Willing to beg for replies...
    SRTopDog is offline LX Newbie
    May 2006
    Running into some of the same issues after having a KW version I installed on my Charger SRT8 and am going to get the camber kits installed front and rear same time as I add the Hotchkis to acheive the alignment targets. Maybe that would work for you. Eibach makes them....
    Hope this helps.
    Scott B.
    http://img.photobucket.com/albums/v4...0/IMG_6449.jpg
    Tinted, Dropped, and Walkin' on 265/35/22 and 295/30/22 Vredestein Ultrac Sessanta on 22 x 9 and 22 x 10 ID Luxury 323 Chromed
    "A good friend will help you move....A true friend will help you move a body."
    "Friends don't let friends drive stock."
    magnitude's Avatar
    Burlingame, CA
    Thanks Scott.
    I'm sure the camber kits will work, but was hoping to align w/out more parts/labor. Hotchkis doesn't drop as much as Eibach and KW (potentially) so thought getting back to camber specs wouldn't be an issue.
    Hopefully someone with my setup will chime in.
