I was at track with these for first time yesterday and although one side snugged up to the hub fine the other didn't and luckily somebody saw the rim wobble during the burnout. I remounted it and it was good but not perfect. I had it torqued correctly but it must not have fit somewhere. I read somewhere about people grinding the center bore to get a better fit. How can I determine if this is the issue or if it is an issue with the difference between 5X115 and 5X114.3 causing the problem?
