    imehemi's Avatar
    imehemi is offline LX Padiwan
    May 2005
    Fullerton, CA
    pro kit with Zoomers?
    I want to get the Eibach pro kit, but I don't know if there are any conflicts with my Zoomers exhaust. I read in another post that you have to loosen the stock exhaust to remove the inner A-arm bolts. I know that the Zoomers exhaust is tack welded in and clamped. Can I just break the welds if need be and rely on the clamp?
    SoCalRT's Avatar
    SoCalRT is offline Major Mag Nut
    Lake Elsinore, CA
    I've got that exact setup and there are no conflicts that you wouldn't have with the stock exhaust. You still can remove the Zoomers, as they use the stock mounting locations and push them out of the way to get the bolts out. No biggie
    The only conflict you will have is with the ground, there is only about 3" of clearance with both mods, so be careful out there.
    Later,
    Brett
    imehemi's Avatar
    May 2005
    Fullerton, CA
    OK, enough screwing around on my part. The Eibach Pro-line is going on the car in a few hours. For now, no new wheels, but hopefully in the near future.
