Anyone experience this popping/clunking noise in these vids?
The popping noise only occurs during slow turns.
The noise is being amplified using Steelman wireless chassis ears hooked to the driver side lower control arm in this vid. I have already hooked the chassis ears to every suspension front-end component but I am having trouble narrowing the noise to one suspension component because the noise is heard throughout the entire system. I thought is was the swaybar endlinks and replaced them 3 days ago but the noise did not stop.
The noise in the vid is much louder because of the chassis ear amplification. I know there are a lot of different potential causes of suspension noises, such as inner/outer tie rods, endlinks, sway bar bushings/isolators, upper control arm bushings, tension strut bushings, brakes, steering rack, and ball joints.
I am just wondering if anyone has experienced the exact same noise/symptom shown in the vid. The noise only occurs at slow speeds when pulling into parking spots/driveways or when backing out.
