Here are some shots Jonesey took of my new drag radials.
These are 325/45R17 M&H Racemaster Drag Radial on Centerline billit series "Hammer" custom wheels.
I had them made 17" X 9 1/2", 5 x 115mm bolt pattern W/6" backspace.
W/the 6" backspace the inner edge or the rim will just kiss the stabilizer bar when the car is jacked up by the frame. When the car is lowered, the stabilazer bar rotates forward out of the way. Jacking under the lower control arm or "pumpkin" will also eliminate the possibility of any contact.
They come close, but the tread does not extend past the lip @ the top of the wheel well opening.
Here's the view I hope to give some of the local mustang GTs
This a shot that shows the wheels off. I was going for the old school look. Wouldn't some 17" X 7" Cragar SSs W/low profile "skinnies" go good on the front?
Thanks Jonesey for snapping these pix & taking the time to e-mail them to me!![]()
