Results 1 to 15 of 27
    Pale Rider's Avatar
    Pale Rider is offline Magnum Come Loudly
    Mar 2006
    Western WA
    Pedders Bump Steer Kit
    I just had the Pedders Bump Steer Kit put in my car last night.
    My oh my! I'm telling you, it is a very different car since last night. You wouldn't think that moving a steering rack up by 3mm would be that big of a difference, but it was.
    There is a stretch of I5 going North, right after Tacoma Mall, and before the Tacoma Dome, (for those in WA who know this stretch) where it gets a bit twisty, with rough roads due to constant construction and busted up overlays of asphalt. I have ALWAYS had to be a two handed driver, (with a firm grip on the wheel) in this section, and honestly MANY places. I litterally drove through this section with an index finger and thumb (one hand) with light pressure, through this whole section. NO KIDDING. Anyone that has ever felt the need to grip the wheel hard in a corner with an LX needs this kit.
    My only wish is that Pedders would make one with even more offset for cars lower than mine. Stock cars will benefit, but my car with SRT suspension has been changed for the better. I'd bet cars that are lower than mine (and there's MANY that are) would certainly benefit from this kit, but perhaps benefit MORE from a bushing that's even more offset.
    Let me be real clear here, I changed NOTHING else other than adding the bump steer kit. This did result in a slight bit of TOE OUT, which would not help in a highway situation. (yet the car handled better than before)
    The steering wheel was also just a hair off - it was turned to the right just a bit. I corrected that easy enough by bringing the drivers side wheel in just a bit at the tie rod. It was about 3/32 overall at the locking nut. I originally put it in about 5/32, but after a drive I decided I didn't like the feel, and the wheel was off the opposite direction. So I settled on 3/32. Those concerned will want to have an alignment done, but for toe, I'd prefer to just go by feel. Toe doesn't change camber, but camber changes toe - so it's easy to do the toe.
    GET ONE.
    EDIT: I've now had a few more days to drive the car over the normal commute areas. There are a few areas that I drive that have always bugged me. There's one in particular that is an on ramp to a freeway. It is a semi tight turn to the right, and right of the crest of a hill is an expansion joint. Every day I hit that thing. The car always lurches to and fro when hitting that section, very unsetling. Now, when I hit it, it's just smooth, and the car tracks straight. No exageration here, just drives the way it should. Very happy with this kit.
    2006 Stone White MRT
    Sidewinder Cam, Mopar Long Tube Headers, Magnaflow Cats, Magnaflow Mufflers
    13.422 @ 102.84
    All that and a CHROME instrument bezel! YES!
    Big Boy's Avatar
    Big Boy is offline 2013 or Bust .....
    Feb 2006
    Columbia Ridge, OR
    Chris,
    Glad to see your getting your great car even further dialed in.
    I didn't see a real good picture of your tires and wheels until this get together this weekend. That setup is really looking fantastic on you car, truely one of a kind.
    Scott
    It looks like 2012 will be very good indeed.
    Unless the Mayans are right, then, well, never mind.
    Pale Rider's Avatar
    Mar 2006
    Western WA
    Quote Originally Posted by Becker View Post
    Chris,
    Scott
    Thanks bro! Hope I see ya one of these days, it's been a while.
    13.422 @ 102.84
    bigvin7's Avatar
    bigvin7 is offline LX Newbie
    Pedders is by far the best MOD I have done. Simply just a new car. The bump-steer bushing kit makes a drastic difference to our vehicles and is the cheapest and one of the best improvements Pedders offers....
    '07 Inferno Red R/T
    Mods for GO!: Mopar CAI - Mopar Longtubes w/ high flow cats - Corsa catback - Pedders Track 2 Suspension - JET 180 t-stat - DMH cutouts - BT oil catch can - Diablo Predator w/ CMR tune by Steve from RDP (341.1 RWHP // 371.1 RWTQ)
    Mods for show: headrests embroidered by Jina's - painted bezels and inserts - 22 Elite console cover and leather wrapper shifter, shifter bezel, and door inserts - honeycomb grille insert w/ script logo- 20% tints all around - rear spoiler
    Rob@WretchedMS's Avatar
    Rob@WretchedMS is offline Evil Pedders Guy Since 06
    Jan 2007
    CT/MA
    agreed, they are a huge improvement, espescially on a lowered car.
    Moving it more than 3mm would not really improve anything, the travel has been checked through out the range the wheel moves.
    JusticePete's Avatar
    JusticePete is offline Suspension Specialist
    Jan 2007
    Michigan
    There are also limitations to the OE mount. There is very little room, the rack mount ID, is a limiting factor. That said, if you love your EP2113 Bumpsteer Correction Bushes, you'll love them even more with our DAMPERS at the Damper Days Prices.
    Cheers,
    Pete Basica
    www.PeddersUSA.com
    PGB@PeddersUSA.com
    O 248.522.8021
    Pale Rider's Avatar
    Mar 2006
    Western WA
    Still happy.
    Some cars you can drive with one hand at the 12 oclock position - I never could with this car - just too scary. Now, I actually can. 9 and 3 is still the best, but if I wanted to be Joe Cool, I can do the 12.
    I'm slowly trying to get used to not having to grip the wheel as hard as I have for so long.
    13.422 @ 102.84
    MikeEast's Avatar
    Ducktown, Georgia
    I have the bumpsteer kit as well as the coils-n-shocks and I'd do it again in a heartbeat! Totally changed the overall 'feel' of the car and the steering is now what it should have been from the factory.
    I don't think I got as many of the cool 'bushes' as the picture shows, but I'm totally happy with the package.
    Mike
    Jan 2007
    CT/MA
    Quote Originally Posted by Pale Rider View Post
    Just wait until you replace some of your bushings, and shocks, you'll be shocked all over again! (a little pun there, lol)
    tlrche's Avatar
    tlrche is offline '07 Charger R/T
    Kenner,Louisiana
    i have this kit.. but didnt install it yet. The instructions were a lil vague. Im still confussed as to what this kit does. Anyone have a pic of the install/how it works??
    '07 Charger R/T
    MODS:
    Diablosport Predator -JBA Catless Exhaust - Airhammer - B.T. Embelms -SRT Grill - Pedders Lowering Springs - 180 T-stat - RK Sport Hood - SRT Headers
    Pale Rider's Avatar
    Mar 2006
    Western WA
    You'll probably get a better response telling how to put it in, and maybe pictures, but here's the short answer...
    It raises up your steering rack so there isn't an angle between the tie rods and the rack. So there is much less toe change when the coil springs compress.
    13.422 @ 102.84
    Jan 2007
    Michigan
    Quote Originally Posted by tlrche View Post
    i have this kit.. but didn't install it yet. The instructions were a lil vague. I'm still confused as to what this kit does. Anyone have a pic of the install/how it works??
    1. Remove the two rack nuts and bolts
    2. Press out the OE rubber bushes with a bush press and rattle gun
    3. Insert the new urethane bushes into the rack mount holes
    4. Clock them so the eccentric hole is in the 6 o'clock position
    5. Remove the ferrule
    6. Lube the coarse / textured bush ID with the provided Pedders lube
    7. do NOT lube the exterior of the bush or the rack orifice
    8. Insert the ferrules
    9. Wipe off an excess lube displaced when inserting the ferules
    10 Bolt up the rack using a couple of drops of LocTite RED. They are hard mounts so make them tight.
    11. Have the car aligned to correct the toe
    12. Drive and get a very large SEG
    How it works -- that is Pedders mojo you just installed. LOL It works by better aligning the rack / tie rods to the knuckle.
    Step 13. Excercise your rights. Order Pedders Dampers!!!
    Cheers,
    Pete Basica
    www.PeddersUSA.com
    PGB@PeddersUSA.com
    O 248.522.8021
    SMosher's Avatar
    SMosher is offline NorCalSRT-8
    Modesto Ca
    What was the cost of this bumpsteer kit?
    I'll miss you big brother!
    Jan 2007
    CT/MA
    Jan 2007
    Michigan
    Quote Originally Posted by SMosher View Post
    That is $81.56 to every one and then there is Steve's Special Price $181.56.
    That does include FREE SHIPPING for Steve.
    Cheers,
    Pete Basica
    www.PeddersUSA.com
    PGB@PeddersUSA.com
    O 248.522.8021
