I want to put 245/45/20 on the front and 275/40/20 on the rear. Anyone have any thoughts on this? My wheels are 20"/9"
Thanks
Thanks
Should look very cool.
Later,
Brett
275 is a bit shorter then 245. But I am sure unless you know this you will not be able to tell. It is only the diffrence of about 1 mm.
Go-ManGo! 2528
SRT Suspension, Airaid CAI, Diablo Predator, Magnaflow Catback, Stealth Auto Headlights, Blinker MOD, Nitto 420s, OEM Chromed CSRT Wheels, Custom CF Engine Cover (By ME.), SRT Diffuser, 180 T-stat, some day Cam and Heads, BT Dash Tag.
would this setup work on 20X8.5 rims (245/45/20 on the front and 275/40/20 on the rear) ?
Think the 275's wont work. Too wide for the wheels. Could be done anyway. Only way to know is to check tire manufactures spec sheet for specific 275 tire.Originally Posted by Five Points
2010 SRT8 Challenger...
MODS: Magnaflow Competition exhaust, Roto-Fab CAI.....
I think you have to have at least a 9" width rim to use the 275's.
I believe Netsrac has 275's on an 8.5" rim.
BFNY PERFORMANCE
RIP My Friend
This is the tire sizes I plan on getting. Looking at Toyo Proxes 4.
What offset are the rims?
The original rim I was looking at was only 8.5 wide and was going to put the 275 on it but in Hankook Ventus brand. Somebody else-not on this forum-put that brand & size on an 8.5 and has never had a problem.
Rim I want not avail until mid August so I changed rim & tire selection.
Good luck.
The Toyo Proxis 4 tires are spec'd to fit 9" rims. 20" x 9" is the widest rim allowed for the 245s and the narrowest rim for the 275s. Also, they are listed as being the same diameter (one revolution per mile difference).
To see if you'll like it, sometimes you just have to pull your pants down and take a slide on the ice.
Naked '06 Silver R/T AWD; KW V2s, SC Tuner, JBA catbacks, LED eyebrows, E&G grills (black powder coated), paint-matchedspoiler, mudguards and fogs, 35% window tint, SilverStars, painted calipers, Lloyds embroidered mats. Looking for new shoes..
