Results 1 to 9 of 9
    Silver07's Avatar
    Silver07 is offline LX Newbie
    Jul 2009
    Offset and wheel spacers??
    Hey guys, just want to double check.....07 Mag SE
    Im pretty sure these are what i will need....my new wheels (care of LRBaLLa00) are a 20+ offset and 22 x 9. I need to order some spacers today and want to make sure these are the right ones!
    http://www.custombilletstore.com/product_p/4000.htm
    here's a little teaser!!
    lowryder99 is offline LX Padiwan
    Apr 2009
    Edmonton, AB
    Just curious what you need the spacers for? Do the magnums use a different offset? I have those same rims on my car and didn't need any spacers or anything (2005 300 3.5)
    (If you run the goodyear eagles the tires will rub the knuckle but from what I have read any other 265/35/22 is fine...goodyears just run a little wider and have a rim guard on the both sides of the tire.
    progolfer82 is offline LX Padiwan
    Oct 2009
    SoCal Ride: SRT8 Mag
    if the offset is 20 then you are fine fitting over the brembos.
    Oct 2009
    the 3.5 and RT is different then the SRT8s. They have a caliper clearence issue.
    Quote Originally Posted by lowryder99 View Post
    Silver07's Avatar
    Jul 2009
    Mine is just a base 2.7 SE.....i know the desired offset for the magnums is 15+ to 18+....just concerned about rubbing the control arm.
    Apr 2009
    Edmonton, AB
    My suspension should be the same as yours and those rims didn't rub anything on my suspension (same exact rims, lilballer bought them from the same place I did as well)
    Silver07's Avatar
    Jul 2009
    interesting! I will have to see. I ordered the spacers this morning just in case. If i don't use them i will sell them. thanks
    Apr 2009
    Edmonton, AB
    What tires are you going with? I am 99.9 percent sure that unless you go with goodyear eagles you won't need spacers at all. I have a decent amount of room and I can turn lock to lock with no rubbing.
    89grand's Avatar
    89grand is offline LX Guru
    Phoenix, AZ
    I don't really see you needing spacers either. My wheels are +18, but I do run Goodyear Eagle GT's and those tires are FAT, they look much wider than most other 265's and they do have the wheel guard so I had to use 3mm spacers. If I had used just about any other 265/35 I wouldn't have needed them.
    2000 Jeep Wrangler
    1966 Dodge Monaco 500
