My wheels are 22x9.5 with a 18 mm offset. I did have to grind like 1/16" my spindles right behind the wheel with these wheels because it was barley nicking the spindle in reverse with the wheels turned making a grinding noise. Different brand wheels with the same offset sometimes they hit, sometimes they don't. Typically you would want a 22x9.5 with an 15 or 18mm offset
The 255x30x22's (on mine) will sit lower then the 265x35x22 because the 265x35's will hit the inner fenders keeping the car up a little bit.
35 series
30 series
