Results 1 to 15 of 22
    EXTREME's Avatar
    EXTREME is online now Yes, that is my fast driving award.
    Oct 2005
    Flowood, MS
    Numbers on Eibach Prokit??
    What is the Eibach spring number on the rear of Pro Kit spring. I installed a Pro-Kit back in november and blamed the non lowering in the rear on the Novis (which is one reason). Tonight i installed an 08 SRT shock and the thing may have gone down a 1/4 of an inch. So i got to lookin at the springs. I pulled one out and put it next to a stock spring. It was longer and had like twice as many coils that were very close together!
    I put a Stock Spring on the driver side and the Eibach Spring on the pass side. No difference. WTF?
    Numbers on the Eibach rear springs.
    165327-2
    2873-002
    Pics
    Any thoughts?
    Justin
    US Wheels - Frank Racing - AirHammer - Corsa - AirLift
    22Elite - Billet Tech - 3B Spec HIDs - Diablo Sport
    JT/NoESP - Llumar - Stealth Auto - NavHack
    12.69 @ 109.65
    mexi's Avatar
    mexi is offline thats my sippy cup!
    Feb 2006
    N Misssisspi . Memphis TN
    lots of people with the eibach complian of a rake stance..
    mopar 11
    Corsa Hotchkis ...so far.
    EXTREME's Avatar
    Oct 2005
    Flowood, MS
    i would be alright with a rake if it dropped the rear at least half an inch... It's sitting at stock height?
    12.69 @ 109.65
    Sublimeon24s's Avatar
    Sublimeon24s is offline Got me a Lime, now wheres the Patron!
    Feb 2007
    Orlando, FL
    Did you cut the bump stops? I was told by multiple people you need to cut about an inch of the rear bump stops for the car to lower properly
    2007 Sublime Daytona #667
    Now on 24" Status Symbols
    israel's Avatar
    israel is offline Now That's Woo Ha!
    Seal Beach,CA
    Well you need to let the suspension settle, cut the bump stops and tighten all bolts in ther rear once the car's weight is on the ground.
    EXTREME's Avatar
    Oct 2005
    Flowood, MS
    Can anyone verify if that's the correct spring though?
    My research shows the spring should have 2873.140 on it. These seem to be stamped 2873.002???
    12.69 @ 109.65
    05nvrL8's Avatar
    05nvrL8 is offline ANTI-RICE
    Feb 2009
    San Antonio/TSTC Waco, TX
    side note : how does this effect the ride... curbs and stuff?
    2005 Dodge MAGNUM RT 13.8 1/4, 100.7mph trap (gone... for now)
    1974 Plymouth Duster, daily...
    slow engine
    slow transmission
    slow wheels
    NVRDUN's Avatar
    NVRDUN is offline LX Guru
    Las Vegas
    SRT-8 springs are also Nivomat. Thats why with a stock and lowered spring you sit at same height. Its all in the Nivomat shocks.
    You need either stock not Nivomat or some aftermarket dampers.
    EXTREME's Avatar
    Oct 2005
    Flowood, MS
    whoa... novimat springs?
    12.69 @ 109.65
    Lil Hemi's Avatar
    Lil Hemi is offline If it aint a shakin' its just a fakin'
    Feb 2008
    Walnut Grove, Al.
    Hey Justin, where did you get the springs, those coils do look very tight. I couldn't be happier with the stance on my R/T with the pro set.Got almost a 2" drop on the back. I will not be back in town untill this weekend but I can check the numbers then if you still dont have an answer.
    '08 BEE #935
    1SRT8-2NV's Avatar
    1SRT8-2NV is offline My fuel mileage sucks!!
    Mississippi
    WoW! I would call Eibach tomorrow and verify the spring number and if you have the right spring I would let them settle a little bit and if that doesn't get them to where you want them to be then either go with coilovers (even though we saw how they can sit) or try to trim the bumpstop bushing in the rear but that is going to make a very minimal difference and could cause other issues with the suspension.
    Last resort you could go with a different set of springs?!?
    NVRDUN's Avatar
    Las Vegas
    OOPS, i meant that the SRT-8's also use a Nivomat shock/damper so if that is what you have combined with the Eibach's you probably wont get much lowering.
    1SRT8-2NV's Avatar
    Mississippi
    Not all SRT's have the self leveling rear shocks. I don't believe any of the 08 Charger SRT's have them and that is what shocks he is running in the rear.
    EXTREME's Avatar
    Oct 2005
    Flowood, MS
    Quote Originally Posted by Lil Hemi View Post
    man i would be tickled to damn death if i got near two inches out of the rear! Keep me in mind and check the numbers if you can. I will be tracking down the answer but double check for me please!
    Quote Originally Posted by 1SRT8-2NV View Post
    Yea, The bumpstops are not the problem at the moment. I'm going to change out the stock spring to the eibach and keep the non novis in and go for a ride and let things settle. That was a great piece of info shawn posted on the Z about the sway bar could be holding it up with a stock spring in one side. Which was true on jays car if you remember. We put one side on in the rear and didn't get much drop, then put the other side in and it slammed the **** out! I'll try tomorrow and see!
    Quote Originally Posted by NVRDUN View Post
    True, the novis did a damn good job of keeping the ass up when i installed the rear lowering springs. The other night though i was changing out the novi's for non self leveling shocks which is when all this came up!
    12.69 @ 109.65
    EXTREME's Avatar
    Oct 2005
    Flowood, MS
    all 05-07 SRTs came with Novimats.
    all 08 SRT Maggies have Novimats
    08+ SRT Chally, Charger, 300 Use Bilstein Non Self Leveling Shocks
    12.69 @ 109.65
