Results 1 to 10 of 10
    SXT6's Avatar
    SXT6 is offline ///RA - Nation's Finest
    Feb 2009
    TN
    Red face Now my alignment question
    Ok, so my suspension goes in tomorrow, alignment Friday. But my question is, since the car will be sitting lower and closer to the SRT stock height than any of the settings in the alignment shop's computer, are you guys having them align to the SRT specs? Or are you having them try to bring the car back to the R/T, SXT, or whatever? Thanks for any help
    Rob@WretchedMS's Avatar
    Rob@WretchedMS is offline Evil Pedders Guy Since 06
    Jan 2007
    CT/MA
    by suspension do you mean just shocks and springs, or do you mean bushings also.
    Mar 2008
    Your car isn't that low. There shouldn't be a problem. Maybe try a different alignment shop. They should know what they're doing.
    PPP stage 3 heads, Howards cam 219/227 .600/.575 112 +4, ported 6.1 intake, MMPG 85mm throttle body, MSD "Blaster" coils, JBA headers & mids, Corsa exhaust, Paramount "Dominator" torque converter & stage 2 valve body, BC Racing coilovers, Eibach sways, BWoody links, Razorsedge brace, 226mm Getrag 3.91 LSD, Wilwood "plus 2" big brake kit by TCE
    SXT6's Avatar
    Feb 2009
    TN
    Well i take it Friday, it's lower than an SRT for sure. And by suspension (for me) I mean springs and shocks
    Jan 2007
    CT/MA
    Then stick with the standard specs for the car, you will likely have your camber out of specs but with out other parts you can't help that.
    be sure to check your Radius Rod Bushings also when it's up on the alignment rack, all you need to do is turn the wheel left to right while up on the lift (drive on lift) and not on the turn plates so you are simulating actual forces. (click on the bottom pic in my signature for a short video)
    SXT6's Avatar
    Feb 2009
    TN
    Quote Originally Posted by Rob@WretchedMS View Post
    Cool man, I appreciate it a lot. I was just going to get it aligned first, before I look at adjustable camber parts. Thanks for the look out on the bushing!
    Mar 2008
    AKA Tension struts right?
    Jan 2007
    CT/MA
    yup, sorry habits...
    gameover's Avatar
    gameover is offline voiding warranties
    May 2006
    New Orleans
    Are these new springs and shocks? If so, I'd wait a week or two to let the combo settle in before getting an alignment.
    05 RT . Jett Black . SRT Fascias . UAS . AFEII . Zoomers . Forgiatos . Wilwoods ...
    SXT6's Avatar
    Feb 2009
    TN
    Yeah they are, is that what I should do? I just figured the sooner the better but that makes sense
