Originally Posted by
mattd_81
I just bought my first 300c couple of weeks ago. I bought it from a Chrysler dealer and they had to do front brakes for DOT. After only two weeks of driving I'm getting really bad dusting on the front wheels and my car sounds like a cab. I'm guessing that it's not normal and they cheaped out and bought cut rate pads. I'm about ready to toss these out and replace them but have a couple of questions:
1) Anything I need to know about a brake job on a 300c? I worked on GM's before which was simple enough two bolts holding on caliper two more for the rotor bracket if neccessary and simply use a C-Clamp to bottom out the piston. The back required an adapter to bottom out the piston. Is it the same setup here? What about the back if I choose to do it at the same time.
2) What should I replace them with. I'm in Canada and ussually bought brakes from Carquest and for the most part they're top of the line stuff works great and is much cheaper then OEM. I looked on Rockauto.com and they have a lot of different pads enough to leave me confused and scratching my head. To me low dusting and quite pads are more important then performance as I never plan on going to the track. Some dusting is OK as I do wash my car about once a week. The ones on there now about 3-4 days and wheels look almost black...and the noise is brutal.
Any info is really appreciated. Thanks
