Results 1 to 4 of 4
    ZMagnum's Avatar
    Tucson, AZ
    Exclamation New tire from Discount Tire.
    I started up my Magnum this morning to drive in to work and the TPMS went off and I got a ding. I have the base TPMS so I had to look around to see which tire was low. It was my right rear tire. It was down to 24 psi. I would never have known if it wasn't for TPMS. I love this car!
    So I put some air in it to get it to 37 psi and I checked all around to see if I could find a nail or screw or something. I saw nothing. I went ahead and drove into work. No issues but something had to be up because a tire does not loose that much pressure on its own.
    I found a Discount Tire that had one 18" OEM Goodyear tire instock and made an appt. I went over there and they couldn't see anything either until they put it under water. There was a slow leak from the tread way over towards the side. Still couldn't see anything sticking out. They removed the tire and sure enough there was a screw.
    The tire could not be repaired due to the location of the screw (that always seems to happen to me). So I bought a new tire ($151) as well as a 4 tire warranty ($100). The total was $282 with installation and tax.
    The tire warranty will cover all 4 tires. If I get a puncture and they can't repair it the most I will pay is $41. I know I will get another puncture. I've never driven a car in Tucson without getting multiple punctures. A few months ago I had my Durango in for a nail in the tire.
    If anyone is buying a new car I highly recommend taking it over to a Discount Tire and getting the tire warranty. Dodge/Chrysler does not take care of tires. They will refer you to Goodyear. Goodyear will only replace a tire under warranty if it's defective. If I had gotten this tire warranty in the first place I would be out $41 instead of $282 right now.
    BritishNate's Avatar
    BritishNate is offline How Dare you...She's a Nice Lady!!!
    Phoenix, Arizona
    Good looking out....I have the same warranty on my tires too!!! It is a life saver.
    AZ Modern Mopar Muscle
    Said goodbye to the Maggie and Hello to the Sorento
    ZMagnum's Avatar
    Tucson, AZ
    Also, I have to give thumbs up to Discount Tire. They used a 21mm socket on their air tool. They have 110 ft/lbs listed as the torque spec. for the lugs. They took care of my TPMS sensors. They put my special air valve cap back on.
    Bornagainultimatum's Avatar
    Bornagainultimatum is offline The Servant
    Nov 2006
    Eastern PA
    Good idea. I need a couple of new tires so I'll go to Discount Tire and pick up the warranty on all four. Thanks guys.
    6.1L Hemi Registry # 00801
    JESUS CHRIST is my President!
