Results 1 to 5 of 5
    magic32 is offline LX Padiwan
    Apr 2008
    Indiana
    new tension struts and still have clunk. any ideas???
    just had the right sway bar installed and bushings and also new tension struts. a lot better but still have the dreaded clunk over large potholes. any ideas guys. they still have the car in the shop. we are guessing upper strut mounts, possible bushings. anybody have any idea. they are going to hook up a chassis scope up to listen for sounds.
    06 300 srt is what we are talking about.
    HEMISFEAR's Avatar
    HEMISFEAR is offline Your Friendly Canadian Nemesis
    Jan 2007
    Motor City Area ON. Canada
    Outer tie rods? I've heard some people replacing these as well..
    higshemi-less's Avatar
    higshemi-less is offline 0-60- 3.1, 13.5mpg city, 18.5mpg hwy
    Kitchener, Ont
    ^^^^ Worth looking at, an often culprit. Go with the moog replacements as well. Sorry I don't have a part number for you.
    Stock catback, and stock drivetrain
    RobAGD's Avatar
    Reston, Va
    Check the outter tie rods and check your sway bushings.
    -R
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    There was a thread a couple days ago where elcobra44 solved this problem by tightening the bolt behind the coolant resevoir.
    http://lxforums.com/board/showthread.php?t=159427
