Results 1 to 13 of 13
    tank8289 is offline Supporting Vendor
    Jun 2007
    West Milford, NJ
    Need a little drag radial help.
    Ok so i'm looking at drag radials and i'm just so overwhelmed with everything thats out there and trying to find a damn rim now im getting frustrated on what size drag radial to buy. Ok so i'm putting dr's on all 4 corners (awd), i'm going to be buying an 18x8 wheel and might be widening it not sure yet gonna let the tire decide that if its wide enought that it needs widening. What size drag radial should i get? the AWD's have very similar gearing to the srt 3.06 the awds have 3.07. My rev limiter is a little over 6k i think. what heigh should i go with? some people say 26" is good, some others say 28.5" is good also. Any input? gotta take into accoutn i CANNOT heat these things up burnouts are out of the question so i may have to go quite wide.
    Thanks
    Bill
    Edit: forgot to throw in a little bit of info. 392 stroker spraying a 100 shot so my trap is gonna have to be 110+ i would assume. I'm thinking of getting a run on street tires to see what my trap is like.
    392 Stroker, Builder Bill TC, Builder Bill tranny, LXAS LVLI Tcase, Novi 1500 10.5psi, 150 shot of nitrous, tuned by Josh @ HHP
    slideway's Avatar
    slideway is offline Onward, through the fog
    Jun 2007
    Union co. N.J.
    Sounds like your transfer case is in jeopardy And your rear axles too!
    Jun 2007
    West Milford, NJ
    Quote Originally Posted by slideway View Post
    Eh dont worry about that, i have plans for anything that can possibly break.
    InferAl's Avatar
    InferAl is offline "R.I.P. Lou1355 "The Hellbitch lives On"
    Nov 2006
    NE Ohio
    Isn't much you can do with the 8 in. rim. Not to many choices for that
    Video
    PowerWagon896's Avatar
    PowerWagon896 is offline Clever Disguise as a Responsible Adult
    May 2006
    Waiting on the gravy train
    Quote Originally Posted by tank8289 View Post
    Thanks
    Bill
    W/that kind of TQ, a 28" drag radial would be best W/the 3.07 AWD axle ratio. That would allow you to trap up to about 116-128 MPH @ 6100/6700 RPM in 3rd gear.
    I don't think you will find any that will fit an 18 X 8" wheel.
    If you could squeeze 17" X 9" wheels on it a 275/50 17 M&H would be good, They are not overly wide & would probably not cause a great deal of problems on the front as wider tires might..
    Gabe's Avatar
    Gabe is offline AWD FRI'd 5.7
    Massachussetts
    Looks like a 255/50R18 tire would be 28" tall and would fit on an 8" wide wheel .....
    Also, 275/45R18 is 27.74" tall size, so that might work, but might require an 8.5" or 9" wide wheel as a minimum ...
    Rest In Peace Mom (1947-2010)...Will love you forever...I miss you
    '07 Charger R/T AWD.Ordered 5.21.07, born 6.06.07, mine 6.19.07.Hemi Registry#1549
    Video-full JBA exh.Video-dyno. Video-WOT 60-90. Heads/cam done 3.22.09
    '10 Focus SE 4dr, Sangria Red, auto. Born 7.28.09, bought 8.20.09.
    Mods: hood struts, tint, tinted headlamps/tails, black grille, FRPP susp., Motegi rims w/215-50R16's, Steeda rear sway-bar
    done's Avatar
    Old Hickory, TN
    .............. Any input? gotta take into accoutn i CANNOT heat these things up burnouts are out of the question so i may have to go quite wide.
    I think all of the posters missed this. Drag radials pick up a lot of crap just moving around in a parking lot. The AWD is not going to get them clean, let alone hot.
    How about some "sticky" street tires?
    May 2006
    Just wet em down a bit, chain the rear end up to a stout post & light em up! You might need the trailer hitch receiver for this.
    So what's the problem?
    Seriusly, why couldn't you set the front wheels in the water box & have the track spray a little water under the raer tires.
    You couldn't hold the brake & do a big smokey burn out but you could proably get them scuffed up pretty good by just nailing it from the water box.
    formerice's Avatar
    formerice is offline LX Guru
    Dec 2004
    maine usa
    I'm running the Mickey Thompson 265/45/18's on the rear of my RWD RT on stock RT rims. If the temperature is 60F or above and track prep is good, I can powerbrake to 2800 at the line with no warmup. Last yellow, touch her off and they will spin one revolution, when I hear solid hookup, I slam a 100 shot. My signature was before the cam install, btw. If you have 4 of these babys on you're gonna need a lot of grunt to break em loose. MT makes a 305/35/18 also if you widened out your rims. I ran the car at NEDW at 30F and had a heck of a time to get traction, so temp is critical, AWD is not going to be able to heat em up with a burnout.
    Jun 2007
    West Milford, NJ
    thanks everybody for the input. 17's wont fit over the front brakes so i have to go 18's. there are NO 18x9 or wider rims that will fit the charger awd, abosultely none trust me i looked, if someone finds them i will personally shake their hand . I can get a 18x8.5 rim and widen them. Then from there my options are pretty much wide open. What i can do is try in my driveway we down the driveway real good and try burnouts there but i dont think that is such a good idea. If i can find a good way to clean them off in the staging lanes i should be ok. And the only problem with doing burnouts IN the waterbox or near lots of water is all the water up in the fender will now drip down on the wheels making more problems. Sticky street tires would be great, but sticky enough street tires that are not gonna only hookup on the line, but also make it down the track without any hairy issues would be great, but idk how sticky theyre gonna be.
    Jun 2007
    West Milford, NJ
    Quote Originally Posted by PowerWagon896 View Post
    honestly the problem is i might pull the light post down haha.
    InferAl's Avatar
    Nov 2006
    NE Ohio
    Ask LouZ what he did with his stroker AWD
    Video
    Jun 2007
    West Milford, NJ
    He ran street tires im pretty sure.....and last time i remember he was rebuilding his motor and didnt make many track runs before hand.
