Results 1 to 8 of 8
    ChrisC is offline LX Padiwan
    Aug 2009
    Massachusetts
    Need the Front a 1/2" Lower
    Just added Mopar Lowering Springs and as I was leaving work tonight I realized I need another 1/2" drop on the front...........any way to do this without NEW springs???
    Slave One's Avatar
    Slave One is offline Once GMist, now fully converted MOPARist
    Sep 2009
    Spring, TX.
    From what I have read on here, it is quite commonplace to chop off 1/2" from the front coils to achieve this.
    "Jolie"
    2005 Magnum RT - Mineral Gray Metallic
    6000K HIDs, DIY Grill, DeBadged & ReBadged, DeMolded, Air Silencer Delete, DIY Intake, Superchips 91 Tune, 170 Tstat, 2x PowerSticks out to 4 1/2" tips, Kid Car Seats (+10x2 HP)
    bryan_k47's Avatar
    bryan_k47 is online now Support the Oil Patch buy a Hemi !!
    May 2009
    Edmonton,AB
    I always wondered Would cutting the coils screw up the integrity of the springs ????
    2011 Ram 1500 Sport
    2010 GCSRT8, 20" Gloss Black Fac. Repro's, Billet Tech Bling/Catch can, LMI Frankintake CAI, SLP Exhaust, Diablo Predator, various other shenanighans !!!
    2008 Superbee #558/1000, Traded in and missed
    2005 Crossfire, Traded in on Bee
    lowryder99 is offline LX Padiwan
    Apr 2009
    Edmonton, AB
    If you "have" to cut a coil try and use as little heat as possible (i.e. NO torch) Something like a sawzall or a cutting wheel on a grinder. It won't screw up the structural integrity of the spring, the spring rate could change a slight bit due to the overall length being shorter.
    terrier126's Avatar
    terrier126 is offline LX Newbie
    Nov 2004
    Queens, NY
    take out rubber isolators on top of the springs
    good write up here
    http://www.300cforums.com/forums/sus...ed-stance.html
    also i would give the springs a week or two to settle
    Ghostface Mag's Avatar
    Ghostface Mag is offline Vendor/Shop Car for HHP Racing...
    Jun 2005
    "Somewhere in MD. so you can HATE on me"...
    If you just installed them,give them some time to settle...They might drop a little more...
    Check Us Out Online & Contact Us @ 1-888-894-1115
    HHP/B.E.S Forged 8.8:1 HHP Stage 4 Cam HHP Race Grade Heads ProCharged(F-1D) Zex Meth & CryOČ Paramount NAG1
    Sponsors B.E.S Racing STSuspension AfterFX Kooks Headers Builder Bill
    n2fordmuscle's Avatar
    n2fordmuscle is offline LX Guru
    Dec 2008
    Canton, GA
    Quote Originally Posted by terrier126 View Post
    good write up here
    They removed the rear isolators. I don't think you can remove the front. The rears have a "pocket" for the springs to sit in. The fronts don't. Someone correct me if I'm wrong.
    Apr 2009
    Edmonton, AB
    Quote Originally Posted by n2fordmuscle View Post
    I am currently running no isolators on my car with SRT suspension. The springs on the front seat fine against the upper plate and lower plate on the strut.
    I have had no extra noise or discomfort in the car, it all seems good to me?
