Results 1 to 7 of 7
    lowriderman3's Avatar
    lowriderman3 is offline Rut Ro!
    Low Down Dirty South!
    To My Fellow AirRide Geeks
    Anyone that is running AirRide, running different bags in the front from in the back, or vice-a-versa? I have UAS all the way around, but have been looking at bags that can hold more PSI, and are made different than just the clamp type I have on my car.
    I am looking at putting Slam Specialities in the back.
    GROUNDED's Avatar
    GROUNDED is offline My car is lower then your standards...
    Dec 2006
    wilbraham, ma
    IM running RE5 slams in the back. I think there too small for this car especially with 3 people and gear in the back. I would try to shoehorn in a re6 if possible seeing as the size difference is minimal when compaired to the uas bags and the inclreased volume will help lift the car to ride height at a lower psi. You would probably have to offset the bag to get it to fit in there.
    Eventually I plan on making a wood mockup bag ( 6.25" diameter x 3" tall) with my studs added to it and see where I can make that bag fit.
    My car is lower then your standards _____
    MOL SRT-8's Avatar
    MOL SRT-8 is offline SHOW & PERFORMANCE
    Dec 2006
    SAN DIEGO, CA
    please keep me informed on how it works.
    WWW.SHOWANDPERFORMANCE.COM
    SoCalLX
    Congratuation Del Worsham
    2011 Top Fuel Champion
    ICLOSEM's Avatar
    ICLOSEM is offline Ebony & Ivory
    Jan 2007
    GLENDALE,AZ
    There should be no problem fitting a 2500lb bag in the rear of these cars. you will just need a custom bracket built
    AZ Modern Mopar Muscle
    GROUNDED's Avatar
    Dec 2006
    wilbraham, ma
    the RE6 is actually a 2500 lb bag and has a 6" diameter where as UAS is 5.875. The bag grows .0625 radially. You can still use UAS cups. I am eventually going to swap my re5s for these re6s and see what happens.
    Quote Originally Posted by GROUNDED View Post
    Thanks for that info!
    GROUNDED's Avatar
    Dec 2006
    wilbraham, ma
    slams have internal bumpstops as well!
