Results 1 to 14 of 14
    ONE LOVE's Avatar
    ONE LOVE is offline LX Guru
    Jan 2009
    The Beach- Orange County , California
    My car feels shakie!! Im worried
    My 06 300c srt is not very smooth these days! On the highway and around town its quite "shakie".... i just replaced my brake rotors and pads and I have KWV2s on the way!! What else should I look at to solve this problem???? Our cars ride pretty darn smooth outta the box.... Not anymore Whatcha think??? Thanks for lookin!
    richierevs's Avatar
    richierevs is offline I Need DRs Really Bad....
    Mar 2008
    Stamford, CT
    Quote Originally Posted by ONE LOVE View Post
    Sounds like front suspension. Could be tie rods, ball joints, front wheel hub bearings, wheels out of balance, or a combination. Does the shake feel more in your hands (indicates possible issue in the front) or in your seat (indicates possible issue in the rear)? Can you provide more detail regarding how your car is shaking and any associated noises that you're hearing?
    ONE LOVE's Avatar
    Jan 2009
    Quote Originally Posted by richierevs View Post
    Thanks for gettin at me! Its more in my hands.... When im on a rough highway or a worn road its the worst!! Feels like the front end is "loose".... The tires are fairly new and reciently balanced and rotated...I know i have a leaking strut up front, I just replaced the rotors and pads(because i felt a slight shake while high speed braking)... I still feel a lil shake when im braking... Cruzing also..... I thought tie rods!! Is this a common issue??? Anything like this sound common??
    THANKS FOR THE INPUT
    Coopers_Dad's Avatar
    Coopers_Dad is offline I need a throttle stop.
    Jan 2009
    Niagara Falls.
    I've been trying to solve a 65mph shudder/vibration since I got my car. I've changed inner and outer tie rods, steering rack, rotors, wheels, tires and checked every bushing I still can't figure it out. The strange thing is that it's only ther from 65-70mph above or below it's gone.
    Sorry I'm not much help but if yours is more persistant at a wider range of speeds I would have your tie rods checked.
    2005 Magnum "Superleggera" Hemi Registry #1050
    PB: 12.946 @ 107.19 on a 1.991 60'.
    Built and maintained by HalfFast Performance,
    I fly 2's Avatar
    I fly 2 is offline LX Padiwan
    Bolivar, MO
    I've had a similar issues as yours and it turned out to be an alignment problem and out of balance tire/wheel. I was having abnormal wear on my front tires and a steering wheel vibration at 75-80 mph. I recently had the car realigned and had the tires road force balanced and now the problem is gone. The first time the car had about 13,000 miles on it when it started to have the problem. I had to replace the front tires and had it aligned. The second time was at 19,000 miles and I noticed abnormal wear again on the tires and the shaking steering wheel again. I took it to a different shop this time and they realigned the front and also did the road force balance. I think that the road force balance is the key and a lot of other guys on the forum can testify to that. Hope that helps.
    Bruce
    richierevs's Avatar
    Mar 2008
    Stamford, CT
    Quote Originally Posted by Coopers_Dad View Post
    When I upgraded my suspension I got the same shudder/vibration your describing. In my case, I was able to isolate it to the strut towers. Once I installed a strut tower brace the shudder/vibration vanished. Just food for thought.
    richierevs's Avatar
    Mar 2008
    Stamford, CT
    Leaking strut is cause for concern. It may not be "the" problem, but it can sure make it worse. I'd get that looked at soon.
    Tie rods issues are very common, so is the alignment of the front carriage which includes the upper control arms. If you're going to have the struts replaced (always done in pairs) the shop tech can examine the other aspects of the front suspension.
    ONE LOVE's Avatar
    Jan 2009
    You guyz are great!!! Thanks for the info!! It helps
    cqlink is offline LX Padiwan
    Apr 2008
    Metro Detroit
    Did you have wheels road force balanced? Dealer charges about $40
    The machine costs around $70,000.00 so smaller places don't have the machine (some discount chains have them). Some other "tire centers" will not even know what you're talking about when you ask them if they do road force balancing.
    Be sure your wheels/ tires are road force balanced before you do anything else.
    ONE LOVE's Avatar
    Jan 2009
    Quote Originally Posted by cqlink View Post
    Thanks....
    im going to give this a try!!
    Mango Daytona's Avatar
    Mango Daytona is offline 2006 R/T Daytona Charger
    May 2009
    Odenton, MD
    As already stated, I was thinking it may be an alignment, or balance issue with the tires/wheels.
    Baltimore Mopar Motor Club #007
    Owner of a 2006 Corvette C6
    ONE LOVE's Avatar
    Jan 2009
    UPDATE.... Ive installed KWV2s yesterday and some of the ish is gone!! Now a balance and an alignment!!! WE shal see.... Thx yall
    Apr 2008
    Metro Detroit
    Great mod!!! I'm betting you'll be good to go after alignment and road force balance!!!
    formerice's Avatar
    formerice is offline LX Guru
    Dec 2004
    maine usa
    X2 I recently had my Magnum up over 140 mph and the front end started shaking. I took it my Dodge dealer and told them that it only happened above 140 mph, they took me serious and road force balanced the front tires, yup, they were out a fair amount. No more high speed shake, smooth as clay barred LX.
