Mimimum Clearance Data
Right now I am running 275/35/20 FK452's on all corners. I machined my own spacers etc to make these rims fit and allowed for ~0.3" clearance to the steering knuckle.
Even in hard (roadtrack) cornering, the sidewall/tread has not made contact. As a result I am thinking of going to a 285 or more.
My question is for those who "have" experienced contact, was it a maximum cornering load, and what is the actual clearance at rest.
This might be pointless, as different marques exhibit different degrees of sidewall flex for a given G-load based on tire structure.
If you can, accurate measurements would be helpful.
Thanks!
---VIPER--VENOM--RED--
-------------------------------- Hemissary--at--CarDomain-------------
- You may not post replies
- You may not edit your posts
Forum Rules
