Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By InferAl
Thread: Mickey Thompson Drags
    1362#Sublime's Avatar
    1362#Sublime is offline Chargers, Its all about the Chargers
    Columbus Ohio
    Im have been to t he track 2 times now with my 28in tall M&Hs and I do not like them one bit, the best 60 foot was 1.68 and this was babying the gas off the line. I need something that will hook and move. My boys told me I should of got these instead. Anyone use these slicks, not the drag radials? Did they help your 60fts?
    I once hurd of some Hossiers that were a group buy but cant find any info thanks,
    Iron Mike
    3743 - Mickey Thompson ET Street Drag Tires
    World's fastest DOT-class race tire. Same features as M/T's ET Drags but with a DOT stamp that meets rulebook specs for street tire classes. Tube type for extra sidewall strength, better air retention, and more consistent ETs. Mickey Thompson Compound RatingsMediumSoftM7M5R2R1L8M9L4Compounds General Application Suggestions:L4 - For Dragsters, lightweight vehicles & vehicles without rear suspensionL8 - Good compound for general useM5 - Good compound for general useM7 - Good compound for general useM9 - Aggressive compound for heavy cars, 3000 lbs. +R1 - Special compound for ET Drag RadialR2 - Special compound for ET Street Radial
    Mickey Thompson #672-3743
    Mickey Thompson ET Street Drag Tire 26'' x 11.5'' - 17''LT
    More Details $202.99
    Ships
    Today $8
    Frank Racing Inc
    6.1 431 Stroker ( Fully Coated shortblock set up for Boost, 9.6 comp,), 5.7 Exstream heads w .030 Mill, 2300 Harrop RDP Blower, FRI Camshaft ATI Over Drive Pulley,Labonte Motorsports Meth Kit, Little Nitros Kit, Dynatech Headers/Cats with a SLP LM2 , Pro Torque 3400 Stall, SRT Rear end w/ 3.06 Gears and DSS Halfshafts
    490 HP and 455 TQ Before Motor and Blower Baby
    Best Run to Date...
    11.539 with a 1.599 60ft 4250 Race Weight at 117.58mph
    Thanks to Steve AKA "Frank Racing", And Sohfast94! BAD A$$ Tuner
    InferAl's Avatar
    InferAl is offline "R.I.P. Lou1355 "The Hellbitch lives On"
    Nov 2006
    NE Ohio
    Video
    ujokin2's Avatar
    ujokin2 is offline LX Guru
    May 2006
    Suffolk, Virginia
    What your having problems Hooking with M&Hs? You get a 1.68 babying and you call that NOT HOOKING?
    What the heck do you have the PSI at ? M&H I found to hook better when they are between 21-23lbs COLD.
    Yes alot of us have used or still use the ET STREET Bias ply. They work pretty good IMO. There has been several threads on the GOOD &the Bad & the Ugly of these tires..... the ugly is don't go below 15lbs on those given the weight of the car. The bad is they wear quickly... the good is they Hook when you find the right pressure.
    N/A ET 10.44@128
    Joy ride TT Challenger 9.71@143
    7.5L Aluminum Block 460 N/A 635RWHP\650RWTQ By Lewis Performance Machine
    Quote:
    Originally Posted by Jack SickSRT
    Bring what you got, run it and STFU!
    slideway's Avatar
    slideway is offline Onward, through the fog
    Jun 2007
    Union co. N.J.
    Quote Originally Posted by 1362#Sublime View Post
    Iron Mike
    I had a feeling I would see some report's like this on the 28" tires, I think their to tall for your 3.06 gears. I use the M/T bias ply 26.5" and I like them fine but they even may be a little tall for my stock 6.1 and 3.06 rear. The mickey bias ply's 26.5 would work good on your car but the hoosiers 25.5 might still be the fastest tire on N/A engines with 3.06 gears. ^^
    Ships
    Today $8
    Sorry I put my post inside your post^^ see just above the micky logo
