Results 1 to 4 of 4
    Big Boy's Avatar
    Big Boy is offline 2013 or Bust .....
    Feb 2006
    Columbia Ridge, OR
    Magnum Struts and Shocks-Available
    Monroe Sensa-Trac
    Front Struts - 72248/72249
    Rears Shocks - 5797
    It looks like 2012 will be very good indeed.
    Unless the Mayans are right, then, well, never mind.
    moparman53's Avatar
    moparman53 is offline Finally got a HEMI again.
    Nov 2004
    E Williamson Co, Central Texas
    Padre Dave's Avatar
    Padre Dave is offline Hemi drivin' Pastor
    Tucson & Chandler, AZ
    I saw those too, as I check about once a month for performance shocks. If you read the write-up,though, they are described as favoring soft ride over performance handling. Bummer....I'll wait for Bilstein or KYB, I guess.
    The Lord bless and keep your coming and going!
    Padre Dave
    fletcher323 is offline LX Newbie
    Jun 2006
    Magnum Shocks
    I just replaced my Magnum RT's suspension with an SRT8 suspension off of a Charger. Works great and it is a direct bolt on upgrade. The only issue you will have is with too much negative rear camber and there are camber kits for that. I highly recommend this upgrade especially if you are looking for a firmer more precise ride.
